Is it possible to fit square taper cranks to a fat bike? Are there 100mm shell BB available
And if there are how would I know what length to get for middleburn rs8 running 22/36?
(This may be a plan fuelled by G&T)
I may do this myself in the future, [url= http://www.ridewill.it/m3/en/cycling/1/vpcomponents/20/drivetrain/3/bottom-brakets/188/pin-bottom-brakets/123/ ]Ridewill is the place to get them.[/url]
Click on the 100 (mm) in the "Case" search/filter, they have 6 to chose from in different lengths.
Phil Wood makes a 100mm
[url= https://www.philwood.com/products/bbhome.php ]https://www.philwood.com/products/bbhome.php[/url]
On One used to sell 100mm sq taper BB's, I'm not sure if they still do.
Had a square taper BB from O O on the Fatty with an old FSA chainset worked fine but the bearings weren't that good.Now running a square taper on the Moonie with RS7's got the 164mm version from Ridewill as the Moonie is affectively a 190 mm rear - works great
