Springhill Golf Residence is committed to accelerate the adoption of building practices that result in energy efficient,healthier and environmentally sustainable buildings by promoting credible and practical green building approaches for residential and commerrcial construction.
WATER
Rethink
Is deep clean plan of technological and economical side to manage optimally and efficiently the management of waste water.
Reduce
Is the effort to minimize water leakage by applying the best plumbing system.
Recycling
Is a waste water management process to re-purifying and harnessing.
Reuse
Is recycling water for the need of Green Set which becomes The Power of Spring Hill concept with Roof Pedestrian Deck and Roof Garden.
AIR
By planting more trees to make the area green, and not to waste fossil fuel that could create air pollution. The company has committed to plant thousand of trees and channel more water that fell from the sky to the ground.
Spring Hill Golf Residence has palat a small but comtributing role in preventing Global Warming, which is an condition in which the earth temperature is increasing because of the excessive amount of carbon dioxide which is trapped on the earth surface. This causes world climate to change and melting of the ice in the poles.
DOUBLE DECKER CONCEPT
The two level Infrastructure which has never been applied in Indonesia before, is implemented not only to provide extra comfort but increase green areas on the surface. This concept enable pedestrian area on the surface and vehicles on the bottom. By doing so,air pollution is separated significantly from residents while at the same time create better view and safer areas for the children.BUILDING The design and construction and Spring Hill Golf Residence adopts the concept of "Green Building" which place great importance on harmonious green factor,water and lighting upon house design so as to save energy.
Green building encompasses everything from the choice of building materials to where a building is located. At Spring Hill, the location is obvious, where green sorrounding already exist.Buildings at Spring Hill Golf Residences uses locally made eport quality materials. The reasons the materials are sourced locally sa as to save logistics energy that otherwise be wasted from imported materials.
The buildings itself are designed with great consideration on the environment. All wastes released during construction are recycled for the use of the plants amd environments. Air conditions are designed not to cause pollution. Electricity system are routed to be efficient and not to be over used. Building materials are even prodeuced from environmentally friendly materials.
