SpokelengthTrackWor...
[Closed] SpokelengthTrackWorld SP Dynamo hub to Mavic TN317
5 Users
I'm going to build up a new front wheel for my Fargo with a Shutter Precision dynamo hub and a Mavic 32H TN317 rim.
The rim ERTO is 622
Hub dimensions are here.
http://leonard.io/edd/hub/1299-sd-8-shutter-precision-dynamo-front
If anyone has a spare minute could they double check the spoke lengths for me.
I will have a bash just now too.
Posted : 28/05/2013 9:30 am
I ended up with
L 302mm R 302.9mm
Posted : 28/05/2013 9:57 am
STOP!
you dont want the ERTO, you want the ERD, which for the TN317 is 600mm by the look of it.
are you thinking 2 cross for the front or 3 cross?
Posted : 28/05/2013 10:01 am
and looking at your numbers (302mm) it seems youve gone for 3x with the wrong ERD (622mm)
3x with an ERD of 600mm comes out at 290mm/291mm
So Id just get a box of 291mm. if they do them in odds, or 290mm if only evens.
Posted : 28/05/2013 10:04 am
Oops
3 cross spokes.
Cheers Stoner.
Stoner's numbers sound about right - think I ended up/got away with 292mm on both sides of an LX dynamo disc hub, 3 cross on an Open Pro.
Posted : 28/05/2013 10:11 am
Out of interest McMoo, why did you go for this rather than the magic Rose Shimano N80/317 combo @ £60? Just curious.
Posted : 28/05/2013 10:15 am
Boblo, mostly vanity* and the love of bling.
*matching the rear rim.
Posted : 28/05/2013 10:20 am
That's the most compelling reason after all 🙂
Posted : 28/05/2013 10:21 am
I needed it to have a disc hub too. The Rose bike wheel is great value, I might still go for one for my Harry Hall.
Posted : 28/05/2013 10:53 am
i built mine 290 all round. worked fine.
I measured ERD at 599. EDIT: mine was tn319. So ignore me. maybe
Posted : 28/05/2013 10:54 am
