Spoke length questi...
[Closed] Spoke length question and buying hubs from australia
7 Users
Spoke length calculators ask for pcd, which is the hole diameter and can be found for most hubs, then centre to each flange. Some of companies tend to give flange to flange and offset, am I correct in assuming I then subtract the offset from the drive side on a rear hub and add it to the disc side?
ie F to F of 100 and offset of 10, drive side 90, disc 110
Then the opposite on the front, ie F to F of 100 and offset of ten giving disc 90 and 110 non disc?
Couldn't they just give the data needed for the calculator?!
Also looking at buying some novatec hubs from australia, anyone bought anything similar? Any idea on customs charges if any?
Thanks for any help, had a couple beers and this is doing my head in!
Posted : 15/01/2016 11:17 pm
[quote=chrishc777 ]ie F to F of 100 and offset of 10, drive side 90, disc 110
er, 40 and 60
otherwise you're about right - flange to flange and offset is a fairly standard way of measuring them though.
Not quite sure why you'd import Novatec hubs from Australia though - they're fairly generic and available from shops in the UK.
Posted : 15/01/2016 11:23 pm
Yeah silly error there! Thanks.
For some reason they're less than half the price I can find them in the uk for
Posted : 15/01/2016 11:42 pm
Aren't Superstar a Novatec hub?
Posted : 16/01/2016 12:00 am
By the looks of them probably, still twice as much even with postage though
Posted : 16/01/2016 12:41 am
Have you looked on eBay? there is a Polish seller who has Novatec hubs normally cheaper/HTF hubs than UK suppliers, no issues with VAT/Import duty either as they are in the EU.
Posted : 16/01/2016 1:50 am
As above, try an eu seller as you'll probably get hit for import tax otherwise.
I say probably, meaning you should definitely pay it, but customs might miss it. However Customs is much better than it used to be in this respect so best assume you will pay it.** There is an online calculator for import tax for when your through with the spoke one! Lol
**Other option is to start a multi billion dollar company up and then paying tax in the UK becomes all but a distant memory. 😉 Maybe a bit over the top to just get some hubs though. 😀
Posted : 16/01/2016 2:28 am
Okay so I ordered these hubs from Australia, probably the same seller as yours. I didn't have to pay important tax on them they took about a week to arrive. I think I have all the measurements I took somewhere so I will dig them out later today. What I would say though is spend a little extra to get the interchangeable axle versions I wish I had.
Posted : 16/01/2016 7:35 am
Have a look here: http://www.bikestacja.pl/en/
Posted : 16/01/2016 7:45 am
