Spinner Grind Air 2...
[Closed] Spinner Grind Air 24 forks - O-Rings etc.
3 Users
Hi all
Anyone know the sizes/specs of the O-Rings for these forks and a source?
I have a set that are out of action and all seems good except the O-Rings on the air piston are baggier than a baggy thing and they seem to lose air pressure very quickly and not recover their ride height.
I've messaged Spinner via FB but so far not got a clear answer wondered if anyone here had found an e-bay or similar source (or a service kit) and managed to stop the things leaking air?
Also anywhere else obvious I could be losing air from?
I'd measure them myself but don't have a set of verniers (note to self must order some)
Thanks
Posted : 06/07/2020 11:08 pm
There a European service center address at the bottom of this page - maybe worth an email/call?
https://www.spinner-usa.com/contactus.htm
Posted : 07/07/2020 9:15 am
 pdw
Not sure which FB page you found, but the page for the European distributor in Poland has quite a bit of info in it and looks to be pretty responsive:
There's some service info here, with a comment "Used o-ring at air piston caused air leaking."
Posted : 07/07/2020 12:44 pm
Thanks both. Had a message back from the folks in Poland very helpful and it seems there are two possible seals so time to take apart again and check which.
Posted : 08/07/2020 12:24 am
