Spesh STOUT axle re...
[Closed] Spesh STOUT axle replacements needed, would it be worth it?!
6 Users
Hi Folks!
Advice needed cos I'm not very technical.
I found a wheelset at the dump!
They are DT 445D rims on Stout hubs. Each hub has the axle removed 🙁
Can I get replacement qr axles?
Has anyone got any please?
Would it be worth it?
If I replaced the hubs, is that a better idea? If so what good budget hubs should I get?
Have you got any please?!
THANKS!!!! Paul 07776143890 ieatpies1@googlemail.com
Posted : 01/11/2012 1:42 pm
I have a a 445d with a stout hub in the cellar going for cheap if you're interested - drop me an email and we'll sort sommat out.
PS - The rim is knackered.
Posted : 01/11/2012 1:45 pm
Is the axle itself missing, or the quick release spindle? If so you can buy these cheaply from other companies like DT Swiss.
Posted : 01/11/2012 1:49 pm
Chances are they were at the dump for a reason and I would put them back there . If the "axles" you refer to as missing are actually DT Sraxles , the thick skewer that holds the wheel in place they are about £50 each to replace . Bearings could be shot , alloy nipples could be breaking regularly etc etc .
Posted : 01/11/2012 2:04 pm
Yes, both axles are missing.
Thanks patriotpro I'll mail you!
##Appreciate all your help guys##
Posted : 01/11/2012 2:08 pm
 Pook
I just swapped the hubs for deores when mine went.
Posted : 01/11/2012 2:10 pm
As per the above post: the build quality on specialized own wheels a few years ago was legendary in its badness: alloy nipples to save weight made for frequent failures: a few friends eventually had their wheels completely rebuilt under warranty after several early spoke snappages/failures.
But is the "axle" you see missing looks like it should be a 9/10mm (front/back respectively) tube/rod going throgh the centre of the hubs, then replacements are much cheaper on superstarcomponents.com [url= http://superstar.tibolts.co.uk/index.php?cPath=32&osCsid=84c27c348ad61204ae5972e40786654e ]Click here: (top two products on this page)[/url]
DO you have a friendly bike shop you could ask for an opinion on the bearings and straighness/tightness of the rim/spokes?
Posted : 01/11/2012 2:12 pm
THANK YOU ALL FOR YOUR HELP!!
Got some good ideas now
CLOSED
Posted : 01/11/2012 3:59 pm
