Spesh Enduro Comp 2...
[Closed] Spesh Enduro Comp 2010 Q & A
6 Users
guys, do any of you know if a CCDB Air will fit a Spesh Enduro Comp 2010??
cheers
chris
Posted : 02/06/2013 8:27 pm
If you managed to get one of the ones off the new 2013 enduro it might but a standard one won't, due to the silly link.
Posted : 02/06/2013 9:15 pm
not easily. I modded a coil DB to fit but it was a PITA adapting the standard clevises. If I did it again from scratch I'd get a set of evo links and adapt them as they provide a better mounting interface. You'd be better off just springing for a '13 Enduro with CCDBa as standard.
Posted : 02/06/2013 9:23 pm
ok cheers,
its for my brother, does he need a evo link??
new evo frame with ccdb aor is £3k!!
Posted : 02/06/2013 9:25 pm
Asked Specialized and also Cane Creek importers who both say it wont fit as 2013 has different mounts
Posted : 02/06/2013 9:33 pm
The new one has a rather odd mount with a bolt just screwing into the back of the shock
Posted : 02/06/2013 9:44 pm
anyone know how much the evo link is and how do u get it?
Posted : 02/06/2013 9:55 pm
Any Spesh dealer should be able to get you the enduro evo link but it will not bolt strianght to a db without somersault about
Posted : 02/06/2013 9:56 pm
Can you not buy the shock and mount link from Specialized? Are the mounts to the rocker part different? The rocker certainly looks different than my '11 Evo.
Posted : 02/06/2013 10:10 pm
Just buying the evo link will not work. This will only enable you to fit the Fox rc2 shox you can buy off specislized.
They are bring out a devolution link which will let you fit a CCDB air to the older frames but there only having a very small amount of them in the UK and there going to be mega expensive !
Posted : 03/06/2013 6:14 am
