Spesh command post ...
[Closed] Spesh command post lock on lever help ?
7 Users
Does anybody know of the lock on grip style lever that comes with a spesh command post will work with an ergon grip at all ?
If not will it lock onto the bars without being connected to the end of a grip ?
Cheers.
Steve.
Posted : 01/07/2017 5:23 pm
Should be a rubber insert that allows it to go straight onto the bars. It will also fit most lock on grips by using the clamp insead of the lock on ring
Posted : 01/07/2017 5:35 pm
Renton, I've got the 'southpaw' remote going spare if your interested?
Posted : 01/07/2017 7:37 pm
i said to you chap if you get stuck theres grips for it , just take the grip end off (clamp) and lever fits over a small plastic ridge on the grip replaces the clamp with a lever clamp.....its a pretty clean setup
Posted : 01/07/2017 7:51 pm
if you are interested I have a spare specialized under bar shifter type lever for the command post
Posted : 01/07/2017 9:00 pm
Mickmcd. That you did mate.
I like to use ergon ge1 grips now mate but not sure if the clamp is slightly different to a normal (like odi etc) lock on clamp.
Cheers.
Steve.
Posted : 02/07/2017 8:30 am
no worries thanks for the reply
Posted : 03/07/2017 5:33 am
saladdodger and treklee - how much are you asking for your remotes?
Posted : 03/07/2017 6:32 am
apologies Salad, thought i had replied to you at the same time as replying to Mick.
I will pass on the lever thanks, prefer the style that I have !!
Posted : 03/07/2017 6:56 am
The lever is brand new un used £25 posted
Posted : 03/07/2017 8:09 pm
Saladdodger. If the lever dosent sell I will have it please
Posted : 03/07/2017 8:18 pm
trekked - did you post the lever? Nothing arrived yet.
Posted : 29/07/2017 5:04 pm
treklee - cheers fella.
Posted : 03/08/2017 7:25 am
Required?
Posted : 03/08/2017 7:29 am
How would you attach that to bars silly billy
Posted : 03/08/2017 7:31 am
treklee......... Have you posted it yet? Even a disorganised new Dad is stretching it now - 5-6 weeks...
Posted : 20/08/2017 8:33 pm
treklee/Lee/Liam - Two months and still no remote trigger. I may be passing Stourport soon so could pick it up if posting is a big problem?
Can you get in touch please. Or just send a refund.
Posted : 26/08/2017 7:29 am
