Anyone done this on a women’s camber? I’ve picked one up for my girlfriend and would like to fit it myself internally if possible? Any advice or recommendations?
Fully lined internal routing on the carbon frames, no idea on the alloy.
I've got a 2016 stumpjumper and a post waiting to be installed.
I think I need to remove the pf BB to get access and I don't have the tool.
I'll have to call in at my lbs. I miss threaded BB!
Ah, it is alloy. Think I’ll just take the hit and let the LBS sort it.
I’ve got a 2016 stumpjumper and a post waiting to be installed.
I think I need to remove the pf BB to get access and I don’t have the tool.
I’ll have to call in at my lbs. I miss threaded BB!
Is it carbon? If so, the BB area is a sleeve and you can’t access the cables at all.
also, they come out with percussive force, there’s no skill or specialist tools required. Just a bit of wood (I use a hammer handle) and a mallet. Be done in two minutes.
Yep the bb needs to come out to loop the cable down and up, I fitted one to my old camber.
