Has anyone been able to convert the specialized hubs that come on a 2010 Pitch Pro from the 9mm QR to 10mm bolt QR? What is needed to complete the job if so?
I suppose there's a chance that the internals from the specialized 10mm hubs (from SX Trail etc) work. Would be a wee bit surprising but not impossible- if you want to try it, give me a shout, I've got one in bits in the garage so could post you all the bits I can find (not guaranteed to be all of them!)... Just make a donation to your local mountain rescue or give a tramp some special brew or something
Ive stripped out the original QR and axel, replace the non driveside bearing that was on the axel back in the hub but the new 10mm QR seems loose when fitting back and comparing the original axel it seems thicker in the middle . Im guessing standard 9mm QR axels are 11mm shafts centrally and thats what the issue is..?
