Specialized Grid Si...
[Closed] Specialized Grid Side Wall Issues ?
4 Users
Been very impressed so far with my Purgatory, Slaughter Grid combo on my short travel bike, so much so I was thinking of using the Butcher Slaughter combo on the longer travel bike I'm taking to Spain next month.
...but Specialized tyres I believe come with a reputation for crap side walls and seeing a Control version destroyed recently I wondered if anyone had any experience of the new Grid versions on more aggressive terrain ?
Cheers.
Posted : 25/03/2015 3:11 pm
the butcher GRID and slaughter GRID are two difference carcasses over the purgatory GRID
the butcher and slaughter GRID's are much beefier/thicker than the purg grids (that I slashed) they haven't redisgned the case on the purgatory grid for some reason
if your short travel bike has a slaughter GRID on the back then that's as beefy as they get,
I wouldn't touch control personally unless folk always ride trail centres, and I wouldn't have another purgatory grid, until they update it to the latest carcass like on the butcher/slaughter GRID
for reference which is always a good thing to go off for slash-a-bility look at the weights on the American spesh site
purgatory grid = 725 grams (or similar)
slaughter grid = 950 grams
butcher grid = 920 grams
I wouldn't touch anything under 900 grams for a allmount tyre really and when I have ive had them slashed/fail pretty much immediately
Posted : 25/03/2015 3:21 pm
Never had any issues with either the Control or Grid casings I've been running for the past year and I ride very rocky alpine trains in the north of Italy where I'm currently living.
I'd recommend the Grid primarily because for only an extra fiver you get a little bit more piece of mind and the weight penalty is only 50 grams or so (weighed on my own scales).
EDIT: I'm currently running a Purg Grid on the front and Ground Control Grid rear.
Posted : 25/03/2015 3:23 pm
Garburn, Ullock pike, Three passes, Four passes, Sticks pass, Dollywaggon pike..... and many more have failed to put as much as a mark on my Purg grid sidewalls. They're going to Ciclo Montana next month too, great tyre.
I'm 6'2", 16 stone and not the most graceful rider either. 😆
Posted : 25/03/2015 3:25 pm
Understand that... so anyone tried the new Butcher and Slaughter Grid in tough terrain ? These tyres are 100g lighter and cheaper than most others eg WTB Trail Boss & Mavic Roam, so I'm just trying to see if thats at the expense of side walls that can withstand gnarly conditions, even if they have been redesigned.
Posted : 25/03/2015 3:38 pm
...there you go, thats exactly the answer I was looking for, and I suppose if the Butcher, Slaughter Grid is a new improved design over that then I should be fine !
Thanks Nobeerinthefridge. You should check out the Slaughter BTW, very impressed so far !
Posted : 25/03/2015 3:42 pm
