specialized / formu...
[Closed] specialized / formula / god knows freehub help
3 Users
Ok so bike is a stumpy 2019 expert.
The only spec listed is it has specialized cartridge hubs. Ive spoken to specialized and they suggest it should be a DT swiss hub. This isnt the case.
Last night the bearings collapsed. I need to get this fixed today. Soooo
can anyone help witht he freehub. Ive picked up a couple of bearings this morning and im thinking its a DHT-1481 formula hub. Ideally id like to get a new freehub body (today). Well ideally id like it built onto a pro4 but time and cost is an issue.
so can anyone help with sorting out what ive actually got and where to get bits from?
cheers
Posted : 25/04/2019 9:36 am
ok bearings replaced but i am curious about the tightness of the axle.
%3Fwidth%3D475&imgrefurl=https%3A%2F%2Fwww.amaincycling.com%2Fspecialized-formula-rear-hub-axle-bearings-kit-12x148mm-s170200008%2Fp754242&docid=MCIhYGJgP0VNZM&tbnid=lq9vpvAPGhMSFM%3A&vet=10ahUKEwjUvO_s7-rhAhWtA2MBHaEBC1UQMwiLASg9MD0..i&w=475&h=380&safe=off&bih=676&biw=1430&q=formula%20hub%20bearing%20replacement&ved=0ahUKEwjUvO_s7-rhAhWtA2MBHaEBC1UQMwiLASg9MD0&iact=mrc&uact=8
it looks like that and is clamped on the freehub body. Im guessing that the freehud side should be tight and then the other side with 2 lock nuts just nipped up. I am however concerned about sideload on the bearings.
Posted : 25/04/2019 1:16 pm
Hi Andy
Not sure if it is the same as mine (which I think is a DT "copy" with the drive ring that needs removing on the drive side to get to the bearings) but I just had bearings done by the LBS as I didn't have the tool to remove the ring (Spesh dealer) and the axle is fairly stiff to turn by fingers.
Not sure if that helps or not but I think you are describing the same (and I think correct) method of assembly as my hub.
Posted : 25/04/2019 1:25 pm
Did you buy the bike new?
Take it back and ask them to sort it.
Mrs stu has just had a Pro4 hub as a foc replacement on her Stumpy Evo
I know the same shop have also replaced a few other Spech hubs with Pro4s all under warranty.
Posted : 25/04/2019 1:29 pm
spec are sending a new freehub under warranty.
in the meantime i want to get it going for the weekend so i replaced the bearings. I dont have time to drop it off or have a spare.
ive asked for a price for a pro4..... will see what they come back with.
Posted : 25/04/2019 2:55 pm
I'd try being more direct myself.😉
The standard rear hub really is a piece of shit.
Posted : 25/04/2019 4:41 pm
i agree.
Posted : 25/04/2019 5:01 pm
