There's one on the Levo I am thinking of buying that tends to sink a bit. Tis also a touch notchy.
How complex is servicing? Is it really as simple as in this link?
How to: Simple Command post service. | EMTB Forums
Might be useful as leverage with price
17mm? is that slack or something?
The plot thickens . What would make such a post sink? Poor seals?
They use some sort of air-filled chamber, the valve us under the saddle and easily accessible with a shock pump. The 'notchiness' is a ratcheted system, so it's a design feature rather than a fault, probably. They have all the subtle recoil of a Lee Enfield .303 rifle, but you get good at subtly weighting the saddle to avoid instant knacker retribution. They also give a relatively poor amount of travel for the overall length projecting from the frame. They also have a tendency to pop past the ratchet stop if you're not quite deliberate with operation of the post / weighting it as it extends.
On the plus side, they are one of the few droppers with a layback head and mine has been reliable bar a couple of air top-ups. I've never serviced it, but it seems like a pretty simple creature, so I'm prepared to believe that it's straightforward.
I'd stick some air in the thing and see - carefully - if that sorts it out. Be wary of how viciously it will shoot up and adjust accordingly, bear in mind that it is just a violent thing full stop.
If you want a smooth, non-ratcheted, knacker-friendly post, replace it with something else would be my suggestion. I keep meaning to get round to that, but clearly don't really care enough to actually do it.
I have one on a 2016 Stumpjumper and it started leaking air this year. It does stay up, but won't return after it is been dropped without some help. I have become quite adept at either lifting it by hand or between my thighs. Given the number of times I use it on a normal ride this isn't a great hardship.
I looked into servicing it myself, but quickly came to the conclusion that, like shocks, it's best done by someone who knows what they are doing and has easy access to the serviceable parts. I contacted two LBS's who advertised dropper post servicing. Both said "No" to servicing the Specialised Command Post due to access/availability of spare parts and both said "take it to a Specialised dealer".
Not the first time I have had this issue with Specialised, front derailleur and rear hub parts are very specific to my bike and I had to go to a dealership in Yeovil (Rock & Road) to get them sorted.
