Specialized command...
[Closed] Specialized command post service
3 Users
So I have a second hand command post that has started leaking. I can't manage to get it apart so I was going to send it to be serviced (or at least check how much it cost to service).
Downside is that I can't work out who does services it (apart from Specialized) and I can't find any info on sending it to them. Anyone got any suggestions?
Posted : 13/08/2016 3:09 pm
Give Specialized UK a ring, and book it in. Should be turned around within the week.
Posted : 13/08/2016 3:42 pm
Thanks. I'll give that a go.
Clearly I am from the generation that is confused when you can't do everything online.
Posted : 13/08/2016 8:05 pm
They are a simple mechanical design. Hardest thing for me was getting the top seal off it was pretty tight. If its leaking air it'll be a new top seal so it'll be getting replaced grab it with some locking pliers.
When replacing the seal you'll need the guides to remove and install the seals which I got at the same time as a new seal from the LBS. The parts were about £20
Posted : 14/08/2016 6:30 am
