Specialised enduro ...
[Closed] Specialised enduro 2015 pivot bearing
2 Users
Hi all, does anyone have a link or a suggestion for how the main pivot bearings are removed from my speed enduro 2015? The ones directly above the bottom bracket. There appears to be a spacer tube between the two bearings? Cheers
Posted : 16/01/2018 1:32 pm
The best way is using a blind bearing puller like the one below. These can be pricey though so in my case I took my frame to an LBS and they pulled them both for a fiver I think.
Posted : 16/01/2018 1:46 pm
OK, thought that might be the case, lbs it is then, cherrs
Posted : 16/01/2018 5:28 pm
