Spec me a Lakeland ...
[Closed] Spec me a Lakeland pass storming wheelset
9 Users
Want some new wheels for my bike to replace the OEM ones that are 2.1kg. They will get plenty of rock strikes. I want them to be strong, wide reliable and lightish. Budget £400 max. ish...
Something like a Hope Flow EX is what is my first thought. Pondering DT wheels like the E1700 and also something a bit wider like a Velocity Blunt on a Dt350.
Any ideas?
Posted : 01/09/2015 8:05 pm
Ive been running Mavic 719 rims Hope Hubs (26er) for at least 8 years now, its a combination that seems to find the right balance between strength, weight and durability.
I have ran 2.3 width tyres on the above too with no problems, the Stans flows type rims may be the way forwards though, with a trend towards fatter tyres and puncture protection systems like pro-core requiring a wider internal rim width.
Posted : 01/09/2015 8:16 pm
Will sir be wanting clown size or normal size 650b 🙂
Posted : 01/09/2015 8:35 pm
Not had 19mm rims on a mountainbike since my first custom wheels - Mavic 321 SUP ceramics on DX hubs back in 1993 🙂
Semi-clown, not full clown thanks Rich. Oh and for normal non-attention seeking sized tyres.
Posted : 01/09/2015 9:18 pm
I have had WTB ST i23 rims on Hope Evo in the Lakes for two years -with dings but no calamities, and they've stayed incredibly
true. Bit heavy maybe (rims 520g) but cheap...
Posted : 01/09/2015 10:41 pm
 duir
Knackered 719's, Flows, 721's, etc etc but have a 4 year old set of 521's on Pro II that have been trued once and utterly smashed on the roughest Lakes descents and they are without dents.
They weigh a tonne though!!!
Posted : 01/09/2015 10:45 pm
Another vote for 521's here, ran a set on a hardtail years ago, entered some of the inaugural UKGE rounds in 2011 on them too, swapped them over onto my Saracen Ariel for a while and they did sterling service on that bike..... Never needed trueing, never dented the rims etc....only criticism I can think of (and I'm clutching at straws now) is that they looked a bit boring in plain black!....and may be considered a touch narrow these days at 21mm but I never had a problem sitting 2.35 High Rollers or 2.5 Minions on them.
Posted : 02/09/2015 2:06 am
DT EX471s are really nice. Super stiff, set up tubeless easily and are a good width (25mm internal).
New XM481s are worth a look too, but are likely to be less robust in rock strike situations as they are a similar weight for a wider rim (30mm internal), so wall thickness must be less.
EX471 seemed to hold up well under Gwin in Leogang despite the lack of tyre.
Posted : 02/09/2015 6:39 am
I had 521s on Hopes that were battered as hell for 3 years but never missed a beat. Shame they were on my bike went it got pinched the other year 🙁
Its probably a toss up between Hope and DT hubs at the moment.
Rim wise top choices are EX471s or Flows, but those XM481 look tidy.
Posted : 02/09/2015 9:49 am
If you're looking at Flows I'd consider these too...
http://www.superstarcomponents.com/en/superstar-t-ready-ds25.htm
They are significantly cheaper, a mere 10g heavier and [i]at least[/i] as tough - probably a bit tougher TBH - tested on the four passes and similarly rocky Scottish mountains.
I wrote a blog review on the wheelset...
http://unduro.co.uk/mtb/review-superstar-components-tech-4-wheelset/
Posted : 02/09/2015 10:00 am
I'll also recommend the WTBs. I've had some frequency i23s on the longish travel 29er for 18 months or so and only in the alps this summer has the rear developed a slight wander.
Feel plenty stiff, go tubeless nicely, fairly cheap. You could have the KOMs instead as they're a fair bit lighter but I believe a little less tough. The Asyms which are due out soon split the difference I believe.
Posted : 02/09/2015 11:56 am
