Anyone know if you can buy these things? got a couple of kits but no plugs left.
I've seen them on eBay recently.
http://www.ebay.co.uk/itm/141035220559?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Bolt
Ordered, cheers guys
What about the fluid? Is it just normal vulcanising solution? Got the Weldtite plug kit and can't tell.
Going by what's in my panaracer kit, an old inner tube and a tube of bog standard rubber/vulcanizing solution should do the trick.
No glue needed with those, they are just pushed in to plug the hole.
Bolt
If I ride tubeless, some alpine stuff, I usually take a tube with me. But do I need one of these anchovy kits and can anyone recommend one?
The Weldtite ones go for a fiver online. Five plugs, couple of insertion tools and a little knife to trim the plug when done. Comes in a little box, and will do for ages if you buy some of the above refills.
I've had two lots now, the first needed a 3rd slicing off to get them into the insertion tool (didn't bother with the first and it took 10 minutes with some pliers getting it through)
More recently I got another refill, these are double the thickness so chopped them all in half lengthways. I even chose an auction where they seemed slimmer than the others!
Has anyone found a seller of cycle sized anchovies?
Aye, it's just normal vulcanising glue.
I cut all my weldtite anchovies in half. Plenty long enough (you still end up trimming most of it off).
Weldtite rubber solution available [url= http://www.hargrovescycles.co.uk/weldtite-rubber-solution.html ]here[/url] for example.
I just bought two tubes, expecting them to be the same size as the tiny ones in the kits - but they are much bigger!
There is vulcanising fluid and rubber cement. They're not the same thing. Anchovies/weldtite plugs don't need either, the other weldtite kit which relies on strips of rubber cut from a sheet needs rubber cement.
The Weldtite kit comes with a tube of stuff. I just wanted to know what it is, as I can't tell. Seems like vulcanising solution to me but not sure.
The stuff in the Weldtite kit is the stuff I linked to a couple of posts above.
As Scienceofficer pointed out, it isn't vulcanising fluid.
The panaracer kit is pants. None of the plugs stayed in. When the same hole was repaired with a Weldtite kit it was good.
I bought some more plugs off ebay but they are way too big to work with the weldtite tool, might end up putting them in the bin. Can anyone link to a specific product that is the same size as a weldtite plug/anchovy?
And +1 for cutting the weldtite plugs in half. If you're careful fitting, you don't need the full length.
As above most of the ones on EBay are a bit thick for the tool to be used properly. All I do is pull them apart lengthways to halve the thickness and then just trim to length. The ones I have are made up of 4or 5 thinner strands
They are kinda made up in the same way a rope but sticky (obviously) and this means you get even more for your ££
Carlos
Hmn, I'll have a go pulling one apart, cheers.
