Spacers in Hope hea...
[Closed] Spacers in Hope headsets
5 Users
Hello,
I've just received a lurvely new hope mixer headset and the top part (intergrated 1 1/8) comes with three very thing silver spacers between the bearing and headset cover - are these to decrease drag from the sealing? Why are they there?
(on a separate note, lets see if the hope lasts 😀 )
Posted : 12/02/2014 4:24 pm
it's in case the top cap drags on the frame
Posted : 12/02/2014 4:26 pm
Try with all 3 in, if the lip of the seal is making contact with bearing housing, leave them in. If it doesn't touch, remove 1 at a time and so on. I usualy end up with 2 in mine, and if need be, if the seal/housing wears over time, remove another 😉
Posted : 12/02/2014 5:24 pm
Interesting! My only confusion then is why the need for spacers, surely the distance between the top-cap and bearing should remain the same? Unless it is purely a design to allow for rubber seal wear, in which case kudos to Hope (Y) (surprised they dont advertise it tho!)
Posted : 12/02/2014 6:19 pm
It's not just hope that inc those spacers and they are very useful as not all frames are exactly the same
Posted : 12/02/2014 6:37 pm
But most of the time they are included with an integrated headset where tolerances can vary,
I never understand why they come with either a press in or semi integrated headset.
Posted : 12/02/2014 6:56 pm
sorry, misread the integrated bit in your post.
Posted : 12/02/2014 7:02 pm
Opps that will teach me to read properly
Posted : 12/02/2014 7:05 pm
