SP Dynamo Hubs - re...
[Closed] SP Dynamo Hubs - replaceable end caps?
2 Users
Hi all,
I'm pondering building up a dynamo front wheel for the commuter but ideally I'd like to be able to use it on the Sunday bike too, the only problem is that one is presently a 9mm qr and the other is a 15mm thru axle.
Does anyone know if the SP Dynamo hubs have replaceable end caps for different axle types so I wouldn't need to build up 2 completely different sets of wheels?
Cheers,
c.
Posted : 08/09/2016 7:02 am
not stock - you get the sp8x which is 15mm with a QR insert that sits inside the 15mm axle.
but the regular sp8 is not convertable.
Posted : 08/09/2016 7:05 am
@trail_rat - ah awesome, thanks!
Posted : 08/09/2016 8:30 am
word to the wise - file down the insert a bit so that when using QR your hub is held by the drop outs against the hub body rather than the QR insert - or your connector will rotate and the cable will be pulled / pulled out.
Posted : 08/09/2016 8:41 am
