Sorry.....
[Closed] Sorry.....
6 Users
But a tyre question!!!
Santa got me some flow ex wheels so I'm going to get then set up tubeless.
I always run minion dh front single ply front & rear (super tacky front)
Has anyone set these up tubeless and got on ok with them or should I be looking proper Ust tyres?
Posted : 30/12/2013 10:54 am
All Maxxis tyres work well tubeless, I've run Minions & Ardents (and Chunky Monkey / Smorgasbord also made by Maxxis) for years without issue. You need to tape the rims first, Superstar do a 29mm yellow tape which should be spot-on for Flow EX (25mm is too narrow regardless of what it says on Stans website). A set of tubeless valves and some Stans goo and you're good to go.
Posted : 30/12/2013 12:37 pm
Cheers for that, mates using the 25mm with no issues
He is using 2 ply spec tyres..
Posted : 30/12/2013 3:36 pm
Got my Flows set up with 2.5" 3c exo minion up front and 2.3" HR2 TR exo rear. Both went up easy enough and don't drop any pressure.
Posted : 30/12/2013 3:40 pm
...except my Advantage which were made of cheese. Torn knobbles and splits in the sidewall made my Maxxis tubeless experience a pretty poor one. Having more luck with Spesh Purgatory on my Flows, but they're - unsurprisingly - not as good in the winter gloop as they were in the dry weather.
Posted : 30/12/2013 3:49 pm
 sv
Kendo I have a set of dual ply Minion DHF & DHR the front is ST and 2.5 (I think). They ran fine tubeless on Flows, £30 to you if you want them. They have had 4 days in the Alps and I have since sold the Pitch.
Posted : 30/12/2013 4:37 pm
Sv - trying the single play 1st but cheers anyway
Posted : 31/12/2013 4:43 pm
No problems with single-ply Minions here. The newer, lighter 2.25" Maxxis tyres can be risky cos of the paper-thin sidewalls: they go up ok, but I've ripped two within a few rides in the last year.
Posted : 31/12/2013 5:13 pm
well two good rough jumpy test rides and all good.
25mm tape, my old st minion front and a new rear, dead easy inflated and sealed, not lost any pressure at all since thursday...
initial impressions are good 🙂
Posted : 13/01/2014 5:22 pm
