Sora shifter reach ...
[Closed] Sora shifter reach adjustment for cable discs
4 Users
Hi folks does anyone know if it is possible to adjust the reach on these? Is it via the hex screws under the top of the hoods ( have tried these and they dont seem to move)?
Any help much appreciated
Posted : 29/05/2019 1:20 pm
Which model?
For R3000 (current model) there is a screw under the lever hood. For previous models you can only adjust using shims.
Posted : 29/05/2019 1:31 pm
If it's the newer style (where the gear and brake cable both run under the bar tape), just keep winding the bolt in - mine took at least 4-5 full turns before the levers even started to move!
Posted : 29/05/2019 1:47 pm
Ok I think it is the new ones, they are on a 2019 bike, I'll just keep winding then, I wasn't sure if I was turning the correct screws and didn't want to mess anything up
Posted : 29/05/2019 1:49 pm
It's number 8 in this diagram so it does sound like you have the right bit.
Posted : 29/05/2019 1:58 pm
