Had the first off in years last weekend, it would appear that Butchers are skatey as hell on wet roots - actually that is an understatement. They do not hook up at all on wet roots. Between my bad riding that day and the tyres, I went down like a sack of shit with no warning in the most inglorious manner at Coed-Y-Brenin last weekend - between all the dodging of falling trees. 😆 Can't decide what was more dangerous, the tyres or the 70mph winds blowing trees over.
Anyhow, should I just default to HR2's? I've only ever used the old High Rollers, I don't really want to have to go full dual ply and I can't bring myself to pay an extortionate fee for the Schwalbe 1.5 ply tyres.
It's a shame, because in all other conditions the Butchers are great.
What size wheels?
26 inch Marys are cheap, I run a 2.35 on the front.....out back it's a 2.3 Minion DHR2....been great so far this winter although not for proper off piste slop obviously.
In sloppy situations I'll go for a Dirty Dan up front and put the Mary out back.
DHR2 is great on the front until it gets to Shorty time (wet/loamy etc). Prefer it to a HR/HR2.
I'm lazy and quite good at riding any old tyre through deep mud, so spikes are out. Pointless unless I was racing a couple of UK dh tracks. I don't want tyres that will squirm like hell.
I will check out the prices on Marys - I'm running 27.5 though 🙁
Thanks deviant. Are any of the Michelin tyres decent on wet roots and rocks?
Is that the Butcher Control? They're quite hard compound - the Butcher Grid is stickier.
Really impressed with the DHR2 3C.
Butcher Grids.....they are stickier but I've read good things about the controls and now it turns out that a few reviews mention that the Grids are skatey.
Maybe it's because it's a dual compound, 42a over 70a rubber. So perhaps the tyre rebounds quicker and doesn't hold a line as well?
I don't like em on the front but they're fantastic on the back imo- they have that mysterious good slip, when they let go they're so consistent and manageable. But I don't think they've got the rubber right for the front. And yep, the Control's a lightweight carcass which has its bad sides but makes it more able to glom around things.
Minion dhf 3C? Highroller 2 is good but not very knobbly for this time of year and can be a bit abrupty-sideways when it's muddy.
Tom, couldn't say about Michelins but I'm intrigued by their mud tyre....all the reviews say there's nothing better but it is draggy as hell on the flat, very much a DH mud tyre if that makes sense....not really for trail use.
Their Magi-x compound is supposed to be as good as Maxxis's 42a/supertacky stuff so I'll be trying their tamer tread patterns out next time I see them in a CRC sale.
Minion 3c,of the selection everyone else was running and clogging (hans, Mary, couple of others) it was excellent on roots, mud and everything else.
Yep, also not a fan of the butcher in the wet slop. Just switched to hillbilly which is very good in our terrain but may not suit what you're after. The grid hillbilly is quite a beast of a tyre.
How much mud will you be riding?
If mostly firm trails then hr2 3c exo.
If a significant amount of slop then magic Mary.
Unfortunately the Mary you need (snakeskin trailstar) is not in stock anywhere. I know this because I want one in 650b too.
Butcher grid = my fav allround tyre. Only situation it cant handle is sticky mud, but around here (wet mud+roots+chalk) its fantastic front tyre.
Horses for courses I suppose
What tyre pressure were you running? You can run the grids quite low (20psi), I'm 15stone in riding kit.
Happy to run the 1.5 ply Marys instead of the snakeskin model.
I was running about 24 psi at the front. My old mans 2.35 Minion DHF hooked up better and that is a really skinny tyre.
So Minions, Marys or HR2s then. Thanks for the advice guys, tyres can be quite an expensive mistake these days. Will leave the butchers for the the summer.
disappointing. was hoping for some kind of saw / cleaver / carcass / striped apron and manic grin story 😥
I tried a puragtory on the front and that was 60a centre/50 shoulders, found them skatey on anything but graded trail centres, they did roll a bit quicker. Put the butcher back on the front, got the grip back again. For me there isn't a noticeable difference between the minion and the butcher.
That's what I had in mind too.
"And stepping fresh from the slaughterhouse the crimson butcher ran,
The steam around his shoulders still, a cleaver still in his hand".
The Kiss - Jake Thackray
I'm happy running a butcher control on our local rootfest trails. Is yours pumped up hard? Brakedrag less?
I do prefer a minion though. 2.35s will hook up better in the slop. I don't see the point of a wider tyre - maybe in the summer?
It's pointless going by psi as everyone's pump is different. Go by feel. 20psi on my pump is about 45psi on the lbs one!
Will anything grip on wet roots?
Wet roots are more about technique than hoping for a tyre that offers dry levels of grip. A studded tyre might offer some help though!
Butchers are great three quarters of thw year, but dont have deep enough tread for bad mud, I use a shorty for winter instead
Meh, never had an issue on wet roots before. They certainly felt skatey before the off.
butcher grid here up front and pretty much all my riding is on off camber roots...great tyre.
Wonder if it's the weird 46mm offset on my Reign combined with my new 35mm stem then, not loading the front tyre up enough?
Still, some here seem to think that they are bad in the wet as well.
In regards to the Shorty
Extra care does need to be taken on wet roots and rocks, and while they aren't quite as treacherous as a traditional mud spike can be, they'll still slide out quite suddenly if you lose focus on the task at hand. When it comes down to it, the Shorty is still a specialist, and although the range of conditions it works well in is broader than its full-spike relatives, for most riders it won't be a tire that they put on and forget about for the rest of the year like a Maxxis Minion or a High Roller II.
That's the shorty out then. I don't tend to ride mud or wet loam anyway, mostly wet hardpack and wet roots/rocks. The minions tread does seem more closely spaced than then Butchers, so maybe its that.
I tend to find the Butcher is a great tyre most of the time especially when it's dry. I was out last night on the 29er in the slop and found the Butcher ok on the wet roots but I definitely don't trust it the same way I trust a Magic Mary or WTB Vigilante in really shitty conditions.
Maxxis Crossmarks F&R
Brilliant winter tyre 😯
+1 switched from high roller to butcher grid front and purgatory rear. great combo
Glad there's a counter-argument here as I've just bought some based on all the rave reviews!
No tyres work on properly wet slippery roots. I think you are looking to buy a solution to the problem instead of accepting that you are the problem.
There was a thread a week or so back where someone asked about riding slippery roots. Might be worth trying to find and having a read.
I've got them on a Reign as well Tom, and had them on a 29er HT before.
I do find them good all rounders TBH but more for the summer months round here. I'd have thought they were a good choice for CYB, but maybe I've just learned how far they can be trusted.
On this basis...
I'd choose the HR2 myself, it's not as good as a Mary in the mud but a fair bit less draggy I reckon.
On hardpack I think the control casings are a bit too flimsy if you're riding relatively hard and you weigh a decent amount yourself ie >85kg
Running the Butcher Controls on all our bikes, run them at 30 psi. Use them all year round in all conditions and never had a problem. Purgatorys on the back on all but Abigales new Enduro which has a Slaughter.
Always been keen on hr2, but the last 650b one I got was v sketchy when I went to Snowdon, and even a bit iffy on gritstone. swopped it for a hans dampf which I've found v confidence inspiring, hasn't scared me once over the last 6 wet weeks
I'm running HR2s front and rear. Front is the 3C compound and is reallllly grippy.
Rolls well too 😀
bigjim - Member
I agree. I run butchers front, purgatory rear all year on my fs. Wet roots are slippy so angle and commitment are more of a factor imho.
I run Ardents on my hardtail all year too and I keep being told I'll die. So far I haven't.
It's all about compromise imho.
Butchers run fairly soft are as good on the wet roots round here as any front tyre I've tried.
Trailrakers however...
Butcher Grid tubeless here superb tyre shame they are so heavy but rather have the control and toughness they give for the weight penalty!
Love Butcher up front, but not many roots round here. Paired it with a Slaughter on back.
Well, I've spent 20 odd years mtbing - never once had to think of the angle I'm hitting roots at with a decent DHish tyre (outside of not hitting them at a 45 degree angle). I used to be able to just point and shoot and pretend that it was dry.
Will swap to the new Minion 2.5WT's when I swap the wheels out for something lighter and wider.
For now, I'll stick my brother on it and see if he comes to the same conclusion about them - and maybe evaluate my riding - check to see if I'm riding too rear heavy. It's all about psychology though isn't it, it happens to pro level motorbike racers - they can get it in their heads that a perfectly good tyre lacks feel and they back off and they often can't shake it until they try something new.
Wierdly, I ****ing love ardents.
Not been impressed with the Butcher control on the front - lost the front end a couple of times on wet rock.
Butcher control on the front, purgatory Grid on the back.
Well happy everywhere on that combo, all conditions. In fact been using that combo for a couple of years.
+1
And all the last modern tyres I have ridden are 'ok' in this respect. I fit a set, learn their (minor) foibles, and ride until worn out.
If you want to know how far modern tyres have come along, go and take a FireXC, Velociraptor or TiogaDH for a ride...
I have a purgatory on front. Was going to get a butcher for the rear
Is that against the general practice on here?
I run a butcher grid up front all year round, haven't found it really lacking anywhere, sure it's a slight compromise a lot of the time, but butcher/purg does me well.
As another front option - WTB Vigilante?
Tom_W1987 - MemberWell, I've spent 20 odd years mtbing
*wonders about Tom's user name referring to his DOB?*
My 2p, been running a Butcher Control on the front for over a year. Never experienced any extra issues that I wouldn't have seen with the likes of a Minion anyway.
benp1 - MemberI have a purgatory on front. Was going to get a butcher for the rear
You'll have a grippier back tyre, but whatever works for you
15 years and the minion is still king
No, the hr2 is better.
I've been proper mtbing since I was about 3.5 foot tall 😛 but no, that isn't my actual birthdate.
2.3 Butcher's haven't quite got the volume of other 'similar sized' tyres which isn't going to help trying to find some grip when rolling over wet roots. Mine look quite narrow and low profile when parked along side everyone else's Schwalbe tyres.
I also find once the softer outer compound wears away the harder bit of the knobbles which are left are noticeably less grippy (as you'd expect). I still happily run them as a dependable all round tyre.
There you go OP, some reasons which don't blame your riding abilities.
