Sometimes I hate b...
[Closed] Sometimes I hate bikes
8 Users
Day of maintenance and need to get this off my chest before I throw the bloody thing in the lake.
3 rounded chainring bolts, ****ing cheese based shit, now cant remove 30t narrow wide as threads in recess and nothing to grip.
Cassette is stuck solid, will not budge a ****ing inch.
Superstar hubs are a ****ing **** to service, drift out my arse, nothing to grip against no matter how hard you push the inner sleeve down.
I suppose the only positive is I cant commence the extender 40t installation and **** that up as I have no chainring and a stuck old cassette.
Posted : 30/05/2015 12:58 pm
Chainring bolts: http://www.amazon.co.uk/TruVativ-Steel-Chainring-Bolt-Set/dp/B001GSQO3W
Steel, black, with spacer, no silly tool...
Posted : 30/05/2015 1:21 pm
Steel bolts are your friend..
Posted : 30/05/2015 1:23 pm
Would be if I could get the shite Cheddar ones off.
Rear hub bearings out, now to **** up the installation of the new one.
Posted : 30/05/2015 1:49 pm
This is why I love my lbs. They do the swearing on my behalf 8)
Posted : 30/05/2015 2:14 pm
 tomd
You can drill the chainring bolt heads off to get them out with a suitably large drill bit. For the bearings, a bigger hammer so you can pound the wheel to destruction.
Posted : 30/05/2015 2:19 pm
If you're really struggling with it chap, feel free to bring it over with a cider or two!
Posted : 30/05/2015 2:58 pm
Cheers mate, I've put the thing away for today 😥
Did the rear bearings, front are a pig.
Cassette is stuck like nothing I have ever encountered, broke my chain whip in my attempts to free it. I purposely dont over tightenistumped.dm stumped.
The rounded chainring bolts are still, erm, rounded.
Tommorows ride is poatponed
Posted : 30/05/2015 5:00 pm
So the cassette lock ring just wont give? On the front there is a little sleeve between the pair of bearings that you need to push to one end before you have enough of a lip to hammer the other one out.
Posted : 30/05/2015 5:12 pm
Yep, stuck solid, tried boiling water, old seatpost over a spanner for extra leverage. Lest it with some gt85 soaking in overnight and will try tomorrow.
I know whag you mean on the hub, rear had plenty of float to create a lip on the bearing, front barely moves.
Mike, appreciate the offer of help, with which aspect of my mechanical ****wittery can you help? 😀
Posted : 30/05/2015 5:21 pm
Hammer a torx bit into the chairing bolts. The hammering helps break the stickiness and the torx bit should bite enough to turn.
Posted : 30/05/2015 6:00 pm
Tried it, these must be made of a special, extra soft cheese 🙂
Also tried a flat head, same result 😈
Posted : 30/05/2015 6:02 pm
Loving the use of '****wittery'.
Every day's a school day on here.
Posted : 30/05/2015 6:15 pm
