Someone should have...
[Closed] Someone should have thought of this YEARS ago
24 Users
Using the same set of eyes that you don't trust well enough to align your stem to set a tool up to align your stem.
Posted : 28/05/2014 7:35 am
Hah fools and their money are easily parted.
Posted : 28/05/2014 7:36 am
That would actually be very handy in the workshop...
Posted : 28/05/2014 7:40 am
I would buy one if it said " [b]Target Aquired[/b]"
Posted : 28/05/2014 7:42 am
Ben ,I am sure you could make one in a few minutes using an old laser pointer 😉
Posted : 28/05/2014 7:44 am
Seems reasonable to me for workshop use, particularly where you're doing a lot of very high end builds. Not really one for the home mechanics, but at £60 or so it's cheaper than a lot of tools that would get less use!
Posted : 28/05/2014 7:45 am
Im not sure that really works, would be far better if it projected a 90° line.
Posted : 28/05/2014 7:46 am
 iolo
What if one arm is slightly longer than the other like mine are. Then the bars need to be slightly on the piss. What then? Maybe custom angle charts laser printed on the stem?
For that reason I'm out.
Posted : 28/05/2014 7:49 am
I have just been thinking that, yes 😉
Besides, their web shop only seems to ship to Germany.
Know what you mean, I reckon it would struggle on oversized carbon stems too, but interesting nonetheless.
Posted : 28/05/2014 7:53 am
3 lasers,just to be sure.
Posted : 28/05/2014 7:54 am
I already use a laser system for frame alignment [s]because I don't have space for a surface table[/s] because it's more precise and high tech 😉
Posted : 28/05/2014 7:55 am
I have wonky eyes, can never line up a wheel first go, if it was cheaper I'd be quite tempted.
Might have an addition to the 'what's the last thing you built' thread
Posted : 28/05/2014 8:00 am
Reckon somebody could knock something up with a 3D printer + a £2 laser pen that would be just as good.
You could even use a laser line pointer to make it better than their design as it wouldn't rely on the dish being perfect (you could align the direction of the line with the edge of the tyre rather than just centering the dot).
If it was £15 I might buy it just to save the few minutes fart-arsing about, E69 though, not a chance.
Posted : 28/05/2014 8:09 am
Off work today, but I have just sketched up a job* for the 3D printer later in the week
* different design to the original mind 🙂
Posted : 28/05/2014 8:15 am
Can't say I've ever had a problem with it. I once used a plumb bob from the stem to check the wheel was straight and decided that even that was overkill.
Posted : 28/05/2014 8:16 am
Or a bit of string and a weight on the end !
Posted : 28/05/2014 8:17 am
Trimix - Member
if your bike is perfectly vertical at the time
Posted : 28/05/2014 8:19 am
That's a lot more effort than using this tool though. The only thing that detracts from that is the price, and frankly it's cheaper than a workshop quality chain tool, so if you're doing a lot of bike builds it seems to make sense.
Posted : 28/05/2014 8:20 am
 chip
I just use my eyeballs, if I cannot tell if it is discernibly out either way by looking at it, that's good enough for me.
But a proven laser tool for the job would be good for shop use.
Both for saving time and for demonstrating the bars are true to an awkward customer who may think try are not.
Posted : 28/05/2014 8:35 am
If I had that, and my handlebars were therefore perfectly aligned, I'd be riding in circles as my handlebars have never been perfectly aligned before.
Posted : 28/05/2014 8:46 am
My squinty eyes always balls it up! Often it's because there's a front mudguard fitted that deceives as it's never perfectly straight, other times I'm just too tired/tipsy to manage....
Posted : 28/05/2014 9:41 am
 igm
With 50mm stems and fat bars I'm finding it difficult to great them straight first time - but 60 odd quid. Hmmm...
Posted : 28/05/2014 10:15 am
I have a solution...
Posted : 28/05/2014 10:20 am
As with another poster, since I shortened one side of my collarbone by a centimetre or two, I now ride with my bars deliberately a little off-centre too. A calibration system is definitely required!
Posted : 28/05/2014 10:30 am
I'm not too fussy about the setup of my bike generally, but I get fully OCD when aligning bars, to the point where it drives me to distraction. Then you take it out to find it's still not perfect. So if it works, it gets a thumbs up from me.
Posted : 28/05/2014 10:36 am
iolo - Member
then you are a freak.... 🙂
Posted : 28/05/2014 10:39 am
If there are at least 2 iPhones (or other similar device) in your household with the digital spirit level app (or you have an actual digital spirit level) then you already have what you need to do this. Easiest with an assistant, stand the bike up on it's rear wheel and place one device across the stem face plate and one across the fork crown, get them both reading the exact same, and tighten the stem.
Posted : 29/05/2014 8:49 am
I use the front edge of the handle bar and the tips of the dropouts to line mine up (do both dropouts come into view at the same time as I move fore and aft).
This technique may not work so well with my new Lefty equipped bike - first world problem 🙂
Posted : 29/05/2014 9:07 am
ffs ) sight up the front edges of the fork dropouts and the front edge of the bar at equal distance either side of the stem, ideally where it's not tapering. Easy at the right viewpoint.
 gazc
clearly aimed at people with better cash flow than eyesight
[img] https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQGydsCiXYcLfvs1H3gJaqgoN_ZXHmWogvkPKRp-DXZjeyX29267g [/img]
Posted : 29/05/2014 10:46 am
That's where your method becomes considerably more hassle than just eyeballing it 😉
My annoyance is when building a bike, I get to a point where I have to take it off the stand, get the bars straight and tight, then put it back in the stand again to continue building. It's a bit of a faff. Worse when building Bromptons, because they can be harder to eyeball. So for me, a gadget that I can quickly put on a bike in the stand to get it straight would be handy.
Posted : 29/05/2014 10:50 am
Without a doubt, and I just eyeball it normally but if you are very picky about it being straight and suffering from a bad case of stem blindness, there's a way of getting it straight.
When I was building bikes full time I just nipped it up approximately straight, set up the levers, cables etc and only did the headset and stem at the very end when I lifted the bike out the stand. Either that or swung the bike front wheel down enough that I could easily look straight down on the top of the bars, albeit from in front of the bike, not riding position.
Posted : 29/05/2014 10:58 am
