Soft Rockshox Tora ...
[Closed] Soft Rockshox Tora 302s
9 Users
My forks have gone hell of a soft. If I just pull the front brake a bit when I'm rolling the whole front of the bike dips now.
I opened the left leg and there was a lot of water between the preload adjuster cap and the plug that sits on top of the spring. It doesn't seem to be any different now that's gone though. No sign of any oil leaks.
I've had bother with them before with the lockout working some days and not others. Are they just rubbish forks?
Posted : 01/01/2010 9:45 am
air or coil? if coil you have eaten too many pies/compression damper needs a service
if air - pump em up
Posted : 01/01/2010 12:13 pm
they are crap
Posted : 01/01/2010 12:19 pm
If it's an air version, you might have lost air and just need to put more in. Could be a problem with the compression damping whatsit. 302 has a simple unit with lockout and a fixed compression damping setting when not locked out. Does the lockout still work?
Normally they're tough and reliable and run for years without servicing, but if you've never had them serviced perhaps now is the time.
Posted : 01/01/2010 12:36 pm
Coil, yeah. I'll see if I can find a servicing manual online.
Cheers.
Posted : 01/01/2010 12:46 pm
If you find a good one can you link here? My coil ones need a bit of love now after two years of zero maintenance...
Posted : 01/01/2010 1:18 pm
[url= http://www.sram.com/en/service/rockshox/view.php?catID=1&subcatID=10 ]Here you go[/url]
Posted : 03/01/2010 1:27 pm
toras have a big problem with the rebound assembly,i used to have some and had to send them back to manufacturers to get a new one one fitted free of charge,or your local bike shop would be able to source the part required for you.With that problem they were really soft and had no lockout,also there was oil leaking out of the lower leg.
Posted : 03/01/2010 2:16 pm
Well, the laddie in the shop conceeds that they're soft but says there's no fault and I just need a stiffer spring. Pointing out that they were fine until recently led to a bit of umming and ahhing so they said they'll take a look at them and let me know. I don't suppose the warranty's going to cover it unless they admit there's a fault in the first place though. Nor is there any point in paying those guys to service them anyway to fix a fault they don't think exists.
Hmmmmm :O/
Posted : 07/01/2010 1:48 pm
coil broken maybe? seems unlikely though
Posted : 07/01/2010 2:00 pm
Gordy - I've got some as new 318s for sale if you're interested:
http://www.singletrackworld.com/forum/topic/fs-rs-tora-318-solo-airs
Posted : 07/01/2010 2:28 pm
No thanks, mate. I'll see if I can get these ones fixed first.
Posted : 07/01/2010 7:26 pm
One of the coils hasn't snapped has it? Not quite sure how it would affect it exaclty, but just something to rule out
Posted : 07/01/2010 7:30 pm
I'll have to wait and find out. The shop's supposed to look at it today.
Posted : 08/01/2010 9:28 am
Hmmm - well they're sticking with their original position that there's nothing wrong with them which leaves me a bit stumped.
I don't like 'em as they are so I suppose I'd better buy those 318s after all or get the x-firm spring for my 302s.
Posted : 08/01/2010 7:24 pm
Noticed that the preload was wound down hellish tight when I picked them back up from the shop and they've only broken a plastic it inside so it just spins and spins now.
Took them back to Edinurgh Bike Co-op again today and they're trying to charge me for the part!
"You must've forced it too tight, mate."
Buggers. Trying to push it through as a warranty issue at the moment to avoid the whole you-broke-it-no-we-didn't situation.
Posted : 17/01/2010 6:29 pm
Err, just been nattering at work about it and my colleague says that's par for the course. If they broke the preload adjuster while having a look at it then I *should* pay for the parts according to him.
I could bring myself to agree if it had just broken through weakness but in this case it was "forced" apparently. If it broke without being forced then surely I still win under warranty, right?
Or a meringue?
Posted : 18/01/2010 1:23 pm
* tumbleweed rolls by *
Posted : 18/01/2010 6:06 pm
They broke your forks? Buggers!
I'd threaten to slag them off on here.
Posted : 18/01/2010 6:12 pm
LOL - I'm not sure that'll help. Besides, they haven't yet called to tell me what they plan to do about it so it'd be a bit premature.
Posted : 18/01/2010 7:30 pm
Well, three cheers for Embra Bike Coop. They're footing the bill "as a goodwill gesture". So they should be, right enough, but credit where it's due.
Posted : 20/01/2010 10:28 pm
