Sodding internal ro...
[Closed] Sodding internal routing
8 Users
Droper cable needed doing taped the old to the new as a pull through n it came apart..
Balls
Its times like this I miss my carbon intense as it had all tubed runs and was a doddle
This things a sod.....
So I'm going to swear and shout at it for an hour
Posted : 25/04/2020 11:59 am
Cotton and a rolling hitch doesn't come undone for me....
That said, I'm not buying an internal routed bike again. Changed two sets in the last fortnight, and even with no mistakes its a 20-30 minute job.
My bike this morning was replaced in under 5 minutes. Full length cable on outside of frame, ziptied on.
Posted : 25/04/2020 12:14 pm
Bane of life as an orange owner.
You can have a lend of my park internal routing kit if you need it?
Posted : 25/04/2020 1:26 pm
Same here. Internal gear cable and I have to fit 1.1mm internal to get the gears partially working. External and all is great.
Posted : 25/04/2020 1:45 pm
Have you tried cotton and a vacuum cleaner? Tape off any other holes and suck the thread through to the exit? Or near the exit and go again?
Posted : 25/04/2020 1:48 pm
I used a small screw tied to a piece of string and a strong neodymium magnet to pull it through. Piece of pee
Posted : 25/04/2020 1:49 pm
Vacuum cleaner and cotton is my default get out of jail trick.
Posted : 25/04/2020 1:51 pm
Done only one swear word. Old gear inner and a bent spoke....
Its like fishing but not as dull.
Posted : 25/04/2020 2:10 pm
just swapped my dropper on my hightower v2, internal routing is a dream on that. quite surprised actually as i thought it might be a pain.
Posted : 25/04/2020 2:19 pm
