Saw one at a cx event but I can't find out anything on line. Anyone know anything about them?
Converted into a bike wash I should have explain.
Here ya go fella. My son was looking at these in the summer.
http://www.instructables.com/id/Fire-Extinguisher-super-soaker!-can-be-modded-to-/
thank you
I am not entirely sure what you are after, but a hand pump pressure washer is just over a tenner. Mine works brilliantly and it's so much easier to clean the bike...
Someone had a converted fire extinguisher which had an adapted top so you could pump the pressure back up. I have a cheap garden spray thing too which is good, but the soap suds thing looked neat and worked well.
Stored pressure (pump up) extinguishers used to have schrader valves which you could pressurize yourself after unscrewing the top & filling with water or foam, hardly any do these days though. There are some sill around on ebay etc but you have to get a clear pic of the top to check if it has a Schrader or not. Most extinguishers are now pressurised through the actual operating valve using an adapter.
I've just got one of the 12v water pump kits from ebay (£20) and its really good, I use it for my trials motorbike mainly.
Thanks Dave.
These Fire extinguishers are called Soap Suds Pressurised Pit Cleaner. They are made by a club member selling them to riders from all different clubs. Sprayed in their club colours or in a specific design they want.
They have a Schrader valve and removable cap so can be refilled with water & air.
Thats the one Scottrider - do you know how I can contact them/make an order?
I've past on your email address to Paul who sells them, he'll get in contact with you sts.
That's a cool idea- it's pretty easy to add a valve to a standard extinguisher but the removable cap would make it much more usable.
Thanks.
