I've just trimmed (some might say bodged) a spare Neoguard to wrap round the seat rails and just underneath the silver collar on my new Reverb.
I think it looks pretty tidy. Seemed to work well at keping the muck etc.. Off on the last very wet ride round the local trails. Dead easy to remove, rinse, dry and re-fit.
I suppose time will tell if its an effective method of doing the job.
Anyway other than a mudguard what you using or aren't you?
Carl
Haven't bothered with anything, all ok so far 12 months in
Bender Fender XL
I've got a Gravity Dropper, it's got a rubber boot on it.
hammyuk - Member
Bender Fender XL
Got any pics of how thats mounted?
Not bothered and my Spesh comand post is still fine after 2 years
But I do clean it and put a little silicon spray on it
Nothing. Mines a Reverb and it's been absolutely fine
Neoprene fork gaiter on joplin. Seized after 1 wet ride before fitting the gaiter, been fine since. Seen a fair few inner tubes used as boots, and opened out sections of inner tube used like a neoguard (attach corners to saddle rails, other end to lower section of dropper).
Most reverbs I've seen have not had anything, I assume RS sealing is better than most.
My KS doesn't need one and my Gravity Dropper came with one. Have to admit the mind boggles a wee bit at people who buy a product they don't trust and set about bodging it.
A above; have a reverb and no protection (oo er!) I generally clean it after a muddy ride and make sure there is no mud or grit around the seal.
It's my cable to the remote on my KS that needs replacing as the outer gets hard and brittle, I keep the oat stanchion well greased around the seals and fork juice to keep it smooth.
Didn't say I don't trust it and haven't bodged the product. 🙄 I asked about shielding it from the wet/mud and dirt etc...
I never bothered trying to protect/shield my Joplin and didn't have any issues, just thought I'd see what others are up to
My KS one pulled in some dirt over the first few months, despite the seal appearing to do its job from the outside was full of muck when i came to take it apart for a service.
I cut an old innertube up, slid the post into it, zippie at the top, and fits snugly over the seat collar at the other end, hasn't let anything in since.
looks ugly, but then so does the rest of the bike when covered in crap.
just like that ^
except zippie at the top, and inner tube all the way to the seat collar on KS as it's inserted further into my seattube
Hammyuk - Not sure I can get something like that in a position that would be effective on my Heckler
Nothing on my reverb, no probs after 13 months of getting it carked.
another vote for the inner tube & cable tie method here.
HammyUK, is there ever a time that makes any difference to the seatpost?
amedias - Member
just like that ^
Yeah, mine normally has a tie both ends but occasionally the top one pops off when I lower the post.
It's the XL and yes it makes a difference - seat post stays clean and so does my arse.
Cool... The pic makes it look like it'll not be in the path of the rear wheel water, that's interesting
Best way is to use a fork stanchion cover think there lizard skins it even has a gap in it for the cable to pop out and has Velcro fixing the full length cable tie it at the top job done it works perfectly think I paused £11 toe the two at lbs
This is a pic of what I've done with an old Neoguard.
[IMG] http://i17.photobucket.com/albums/b77/cupton/Joplin/IMGP0210_zps21811138.jp g" target="_blank">
http://i17.photobucket.com/albums/b77/cupton/Joplin/IMGP0210_zps21811138.jp g"/> [/IMG]
I cut the bottom velcro fasteners off ans stitched on some thin velcro that wraps under the sliver collar on the post.
I'll see how it fairs later on
Carl
since that's only enclosed on the one side wont it just collect debris thrown up from the front and hold it near the seal?
Two years with my Reverb - ride all winter 2 or 3 times a week - the mud has not caused any issues. The seal is pretty good so I gave up with home made mud protectors in the end.
TF Tuned serviced it once, said it was fine.
amedias - Member
:idea:Now thats a good point and something I've overlooked. I'll give it a bash tonight and if it does, its coming off and I'll run it with nothing.
There seems to be a good opinion that the Seal is decent enough
Ta
Carl
Fox DOSS, no protection but use Brunox Fork Lube spray to clean up the seal after every ride (squirt, compress/extend and wipe). Prob nearly a 1000km of riding over the winter and it's faultless so far.
I reckon the DOSS despite it's 'unique features' might even prove to be more reliable than the Reverb…
crud comes off tangentially not radially and the guard doesnt intersect the tangent from tyre to post in the pic, but I guess it does do once the rear suspension is compressed.
In my case I did trust it, it filled with water and seized solid on the very first ride. Only reason I didnt immediately send it back was because it was day 1 of a weekend riding in wales. Been fince since fitting the fork gaiter though.
My reverb top seal got a bit stictiony so I took it to bits and gave it a clean and lube t'other week. It was muck causing it. Pretty easy to do.
Simon - MemberI've got a Gravity Dropper, it's got a rubber boot on it.
wot he said
rOcKeTdOg - MemberSimon - Member
wot he said
What they both said.
Funny how people complain about them being ugly then bodge something on whatever else they end up buying. 🙄
Noticed recently fender bender seems to do the trick 🙂
I got one for Xmas and the boot came off top and bottom on the first ride and it now feels a bit gritty, so I'm not feeling as smug now 🙂
Use a section of inner tube on mine. Zip tied at the top, covers the whole post so nowt gets in. Doesn't look the best but it's covered in shite most the time.
[u]the boot came off top and bottom on the first ride[/u] and it now feels a bit gritty
i think youre lying
Ham yuk
That fender bender looks good is it a specific rear one or a front adapted for the rear?
It's XL that they now do.
They are working on an offset one too from a pattern I sent them for protecting the front deraileur.
I had to use a standard one on my HT Kona but the Cube has on offset swingarm so unless the tabs are offset there is no way of fitting one there.
Watch this space 😉
You don't cover your forks so why cover your Reverb??
@h4muf - Well for me, giving the forks a lower's service is a doddle (maybe the Reverb is too, but not looked into it yet) so can clean the rubber seals at the same time and they aren't in direct line of fire from all the shite I ride through, where as the seat post is.
Anyhow just returned from tonights ride and I must say the adapted Neoguard works a treat
I have covers on the forks - after ****ing up a stanchion last year - £11 is worth it.
