Snapped seatpost
[Closed] Snapped seatpost
3 Users
So I managed to snap my aluminium seatpost last night I'm after some advice on what long carbon fibre seatpost is recommended. To go in 2011 st4?
Posted : 12/06/2011 2:13 pm
Sorry to bounce but as well as recommendations I need to check where you measure to get the right diameter - is it the inside wall of the frame to inside wall or outside wall to outside wall of the post?
Posted : 12/06/2011 3:32 pm
It's likely that the diameter is written on the snapped seatpost - normally near the minimum insertion line.
According to [url= http://www.orangebikes.co.uk/bikes/st4_se/ ]this page[/url], it's a 27.2. What make was the one that snapped?
Posted : 12/06/2011 3:34 pm
It'll be 27.2mm I.D.
Posted : 12/06/2011 3:36 pm
Thanks DruidH, great minds think alike as that's the page I was just on.
It was a basic Orange one which came with the old 2009 ST frame and I transfered it onto the new frame. Went quite slowly as I put my weight down on a non-technical bit of track so no removing of alu shards from rear required thankfully! Panick was that it was the top of the frame going as I run a lot of seat-post, Just 1 cm less than the min-insertion mark, hence my thinking to go for a longer one, plus carbon to keep weight off.
Posted : 12/06/2011 3:44 pm
Just buy a thomson.....like everybody else!
Posted : 12/06/2011 3:45 pm
