Smoothie Mixer Ques...
[Closed] Smoothie Mixer Question??
3 Users
Hi
Could anyone tell me if the On One smoothie mixer headset will fit my Niner EMD 9 Frame???
Thanks
Posted : 05/06/2013 10:08 am
bump
Posted : 05/06/2013 7:53 pm
on this site it says your frame takes a 56mm lower shell diameter headset:
http://www.ninerbikes.com/emd9
here it says that the mixer fits the C456 and uses a 49.6mm shell:
http://www.on-one.co.uk/i/q/FROOC456P/on_one_carbon_456_frame
So my guess is no.
Posted : 05/06/2013 8:06 pm
As above ^
and looking at the picture it shows a zero stack lower cup for a tapered fork so basically a 1.5" zero stack (semi-integrated) where the bearing sits up inside the headtube (but still in a press in cup).
It also says its zero stack in the description. The top of the smoothie headset will fit but not the bottom. I would just go with Hope pick 'n mix. You want the 44mm zero stack upper and 56mm zero stack lower.
Posted : 05/06/2013 8:25 pm
Thanks
Bought a Hope!
Posted : 06/06/2013 9:00 am
