smart phone gps tra...
[Closed] smart phone gps tracker app
7 Users
Hi all, finally joined the smart phone revolution and wondered if anyone could recommend an app for my HTC One that allows live tracking either on a home pc or on another phone. Only asking as I usually ride alone for 4-6hrs and it would be a great safety feature allowing family to know where I am during a ride.
Cheers all
Posted : 02/06/2013 1:52 pm
map my ride does if you go premuim iirc
Posted : 02/06/2013 1:58 pm
not sure a smartphone battery will last 4-6hr with the gps on, and presumably also reporting its position via phone signal
Posted : 02/06/2013 2:45 pm
I recently used Real Time GPS Tracker app for android for a charity C2C. It links to a Google map on a webpage and shows current location and also a track of where you've been.
It will show up to 1000 data points so will work over several days and is totally customisable in terms of time between updates, etc. I had it set for 5 minute updates to ensure battery life as the first day was about 9 hours (I still had 50% battery life at the end as the GPS is only activated briefly to lock the position at the preset intervals). It worked perfectly apart for one small section when I forgot to switch it on.
Here is the map for our ride (ending at the pub afterwards) - http://www.greenalp.com/RealtimeTracker/index.php?viewuser=coast2coast
Posted : 02/06/2013 3:23 pm
Viewranger is the best, but endomondo will do what you need. Either app coupled with a [url= http://www.mophie.com/product-p/2370_jp-htc-one-blk.htm ]Mophie juice pack[/url] for the extended battery life should do nicely.
I use Viewranger and the Buddy Beacon feature for live tracking. Works well.
Posted : 02/06/2013 3:31 pm
Cyclemeter will post map and updates to Facebook as you go, (if you let it...)
Posted : 02/06/2013 4:44 pm
Thank you, i'll be sure to check out those recommendations 😀
Posted : 03/06/2013 4:40 am
