im looking at buying a Giant XTC
i am 5' 10" with 30" inside leg
my crutch was just touching the top tube when stood over it on the large
better clearance on the medium but felt like i was stretching from seat to stem on both. small was not available in store but a medium talon with 57" tob tube (small XTC has 57.5) was, that fitted like a glove!
would a small XTC be too small for me check the measurements below & give advice please
XTC
[URL= http://img23.imageshack.us/img23/4234/xtcl.pn g" target="_blank">
http://img23.imageshack.us/img23/4234/xtcl.pn g"/> [/IMG][/URL]
TALON
[URL= http://img7.imageshack.us/img7/4634/talon.pn g" target="_blank">
http://img7.imageshack.us/img7/4634/talon.pn g"/> [/IMG][/URL]
thanks in advance
at 5'10" which i am too, I'd usually say a medium would be about right, you can always put on a shorter stem or move the seat forward a bit, buy an inline post.
im torn
i can get small or large 2009 XTC2 for £650 or a medium 2010 XTC2 for £770, £650 is much more appealling but not at the expense of a wrong sized frame
standover height is stated as 76.1cm on small XTC & 30" inside leg is 76.2?
can anyone else give an educated opinion?
I am about the same as you and ride a 15" merlin and a 16" on one.
The Merlin is too short for me in the top tube (but the stand over is excellent) and is running a 90mm stem (don't like going longer) and a layback saddle moved as far back as I can.
Geometry here:
The On One has a much longer top tube at 600mm effective but still a nice amount of standover. I run that with a 70mm stem and an inline post.
As long as you can stand over the medium okay that will probably be best if you like a short stem. I would rather go shorter stem than fit a long stem.
You seem to prefer the small but I would just worry about feeling cramped on it after while as I now do on my Merlin with a similar 57mm top tube.
