small (ish) 26er re...
[Closed] small (ish) 26er recommendation please
4 Users
mrsoath has a pretty heavy framed bike. So it kinda puts her off coming out. Can anyone recommend a light 26. Straight steerered frame for someone who's around 5'8"?
Many thanks!
Posted : 01/04/2016 5:38 pm
Ohv yeah, have wheels, drive chain, fork already.
Posted : 01/04/2016 5:39 pm
Kinesis?
Posted : 01/04/2016 6:12 pm
Not wanting to pee on your chips but 'heavy frame' probably isn't the reason th bike is heavy.
The lightest carbon frames are around a kilo, a quite heavy steel frame is two and a bit kilo so at best you're going to save a kilo (~2lbs) by swapping the frame, chances are it will be less as I assume you're not looking at 1kg carbon frames?
If you really want to drop some weight off he bike, and especially make it [i]feel[/i] lighter then look at the tyres and wheels, and then fork ( you can save as much here as you will on a frame if replacing cheapo heavy forks), and then to some degree finishing kit.
You'll save more weight quicker, and some nice light tyres and wheels will have a bigger effect on the feel than losing 500g-700g in a frame.
Posted : 01/04/2016 6:23 pm
Could be a dull frame that makes the bike feel heavy to ride though.
Quite like the OHs 15" specialised rockhopper in a "big bmx" type way as it feels very light agile, even when built up with some Tora forks and bog standard rims (now has my old dual air Revs @100mm and 717 wheels).
Posted : 01/04/2016 6:34 pm
