I'd like a small frame bag for my Puffin.
The bags I already have (an Apidura and an Wildcat(?)) don't fit well with the bottle cage when a bottle is in it - the placement of the cage in the DT seems unnaturally high up it.
I could move the cage down with a WolfTooth, or similar, adapter but I don't need a huge bag - just enough for a tube, CO2 and a multi tool but a fat bike tube is mahoosize.
Any good suggestions? I'd rather not go full on bargain basement as hopefully whilst the dropper is in it will be a longterm addition so something that will last.
All suggestions most welcome.
M
Ive got an Ibera frame bag which is probably correctly sized on a 18" XC frame, so on a Large it leaves enough space for a bottle on the downtube.
If you're handy with a sewing machine its quite easy to make one, I keep meaning to make one that drops down behind the bottle cage to store heavier bits.
Have a look at Wee Cog. Lovely kit made by hand in Tweed Valley, will custom make for any frame and probably much cheaper than you expect
76Projects make really good bits
The evoc frame bag works well on my stooge.
Beerbabe will make you a custom one from recycled inner tubes. They are great quality and obviously perfect fit!
Another vote for wee cog. Made to order to fit your bike perfectly. https://www.weecog.co.uk/
If you just want one for a few bits, Wolf Tooth do a "pump bag".
