SLX or XT Shadow+ r...
[Closed] SLX or XT Shadow+ rear mech?
9 Users
Need to get a gs mech, is the xt worth the extra £8-10 over the slx?
Posted : 28/12/2014 11:15 am
The extra cost gets you jockey wheels with bearings on the XT, compared to unsealed plain bushes on SLX, and a few grams difference in weight.
Less clearance for using extender sprockets with the XT.
Posted : 28/12/2014 11:23 am
SLX; when the jockey wheels wear out you can replace them with bearing ones.
Posted : 28/12/2014 11:28 am
Oh right cheers.
It will be used with a one up 42 tooth sprocket and rad cage with 30/32 chainring so would slx be better then?
Posted : 28/12/2014 11:30 am
I use SLX with a 40T set up and no complaints.
Posted : 28/12/2014 11:38 am
 tomd
I'd get the XT. I have SLX on me and the wife's main bikes and the jockey wheels died in no time. Unsealed metal on plastic bushes. They seem to still be going OK, but may as well pay the £8 upfront for decent jockey wheels + slightly more bling. Other bike has XT and the mech lasts and the jockey wheels lasted until they became throwing stars.
Posted : 28/12/2014 12:29 pm
I dont mind paying the extra, I hadn't thought about which would work best with the One Up stuff.
So has anyone used XT with a 42 tooth and RAD cage?
Posted : 28/12/2014 12:42 pm
Medium cage XT with 42t one up sprocket and rad cage here, no issues
Posted : 28/12/2014 12:45 pm
I've just bought an xt shadow+ with a Radr cage and am having issues with the arm where the cable attaches interfering with the cassette. First I've heard that there was a difference in clearance between xt and slx mechs, but everything I've read where there has been a problem seems to mention XT mechs, so maybe there's a difference. I haven't had a proper chance to fully tune in the setup so it might well be user error in the setup.
Posted : 28/12/2014 12:46 pm
I think the issue is with the length of the hanger, as in the distance from axle centre to fixing bolt hole centre.
So the issue is with the frame not the mech. Short hanger then use SLX instead of XT.
Posted : 28/12/2014 1:43 pm
Ok thanks for that, how do you define a short hanger to a not short hanger?!
Posted : 28/12/2014 10:53 pm
 JoeG
XT nd SLX parts are mostly the same or interchangeable per Shimano's Tech Docs (cut and paste link)
si.shimano.com/php/download.php?file=pdf/ev/EV-RD-M675-3407.pdf
Posted : 29/12/2014 12:50 am
I don't think the bushings vs bearings is an issue, I used to find it was but clutchy mechs seem to go through jockey wheels too fast for it to arise. I'd go with XT, as I am a tart, but frankly if you're fitting a radcage there's very little practical difference.
Posted : 29/12/2014 1:52 am
I run a Deore on mine witha RADr cage and it's just fine and dandy with a 40t expander.
The original jockey wheels have covered over 1000km and are good for at least another in my opinion.
Posted : 29/12/2014 2:40 am
It'll be fitted to a SantaCruz Tallboy LT frame so dont know if you would categorise that as having a short or long mech hanger.....
Posted : 29/12/2014 11:27 am
Sorry, I can't give you an exact dimension. From memory I have seen this issue mentioned in respect to Canfield, Canyon and Lapierre frames but this is definitely not a complete list
Best thing I can suggest is to have a general search, on all forums not just this one, for your frame and desired drivetrain setup, see if any results come up, positive or negative.
Posted : 29/12/2014 11:55 am
Thanks, good shout.
Posted : 29/12/2014 12:39 pm
