Anybody else running an SLX in singlespeed mode ?
Juat interested in what chainring you are using ?
I got an FSA 32T DH ring which fits on the outer position fine but the chain looks like it is about 1mm away from touching the spider arms, also chainline might be a bit dodgy in the outer position, but....
when i put it in the middle position it is not supported by the spider arms properly i.e. it doesn't butt up against the edges on the spider, plus the same problem with it touching the spider
Am i worrying too much, should i just run it and forget it or stick a 34T designed for the middle position on it ?
I think youll find this is the same whatever 32t chainring you fit, even the one that comes with it, ie. a non-issue.
Again not an issue, all the load will be on the chainring bolts anyway, hence why most floks dont use pretty coloured alu ones for singlespeed.
what he said
Cheers, yeah i realise all 32's will be the same, just wondered if it was an issue or not, appears not, running a 1/8" chain which is slightly bigger too i guess
Yeah i have got alloy chainring bolts, time to order some steel ones i think and stick it on the middle position
Never had a problem with them myself...
I run the standard SLX middle ring without any issue at all?
I thought about running the standard one but the teeth look waaaaayyy to shallow and ramped to ensure the chain isn't going to come off and result in a testicle\top tube interface, and for £17 i thought that was a small price to pay to avoid it potentially happening !!
