slipping seatpost.....
[Closed] slipping seatpost...how to solve it.
13 Users
 ton
got a problem with the seatpost on my surly tourer slipping.
built it up using a thomson inline post, and it was fine...but i needed a bit of layback, so fitted a cheap kalloy layback post, and it is now slipping, no matter how much i wrench it up.
measured the post, it is 27.2 as is the seat tube inner. got the right surly seat coller on the bike, which is 30.0.
i have ordered a surly constrictor coller to replace the silver one.
should i go back to a thomson post.
any other ideas, apart from a slither of coke can.
Posted : 05/02/2016 7:50 pm
Carbon assembly paste might help.
Posted : 05/02/2016 7:51 pm
Get one of those seat binders that clamps on the seat post and the frame.
Posted : 05/02/2016 7:54 pm
A little bit of carbon assembly paste cured a slippy post problem I've had before
Posted : 05/02/2016 8:12 pm
Carbon paste seems to have worked for me.
Failing that, every slipping post I've had in the past has been cured by using a Salsa lip-lock seat collar
Posted : 05/02/2016 8:48 pm
Carbon paste here too. Nice not having to do the seatclamp up stupidly tight.
A new clamp is worth a try too, as the regular Surly ones have never worked very well for me.
Posted : 05/02/2016 8:54 pm
Take yer wallet out yer back pocket big yin! 😆
Posted : 05/02/2016 8:58 pm
http://www.xcracer.com/shop/viewproduct.php?productid=351
Works well for me and only a fiver..
Posted : 05/02/2016 9:22 pm
thomson layback was the only cure I found for this problem
The small grooves milled into the post seems to help it grip
Posted : 07/02/2016 8:50 pm
 wors
Lay off the pies! 😀
Posted : 07/02/2016 8:54 pm
I use a mix of brick dust and grease. Both can be found in the shed. Works much the same as "carbon assembly paste" and it doesn't make me sound like a poncy ****tish cyclist
Posted : 07/02/2016 8:57 pm
Swapping grease for copperslip/ other thread guard type material worked for me. Another trick I use is to emery the shiny black paint off a new post 😆
Posted : 07/02/2016 9:08 pm
 aP
Try greasing the thread of the seatpost binder bolt.
Posted : 07/02/2016 9:22 pm
2 out of 3 ain't bad
Posted : 08/02/2016 12:38 am
