slipping seatpost.....
[Closed] slipping seatpost....
6 Users
what can i do to stop it?
its a thomson seatpost in a trex ex9 frame if that makes any difference
i have checked with trek and i have the correct dia seat post
it only slips slightly so not sute if i could get a shim in or not
thanks
Posted : 24/12/2009 8:37 pm
Use a Salsa seat post clamp. Nothing else worked for me.
Posted : 24/12/2009 8:44 pm
make sure you wipe of all the grease?
make sure the seat clamp lines up with the slits in the frame?
sorry thats all i can think of if the post is the correct diameter
Posted : 24/12/2009 9:14 pm
 ton
slither of coke can.
Posted : 24/12/2009 9:18 pm
ton,
i had a look but don't think there is enough room
perhaps you could have a look next time we ride?
Posted : 24/12/2009 9:19 pm
Clean off the grease on the post and inside the frame. Replace with carbon assembly paste. Honest it will work. I got the finish line one of wiggle. Solved the same thing for me!
Posted : 24/12/2009 10:07 pm
 DT78
+1 for salsa seat clamp. Had loads of trouble with posts slipping in my nomad till I bought one.
Posted : 24/12/2009 10:33 pm
