Slime alternatives ...
Slime alternatives for tyre changes
7 Users
Hey all
I’ve want to swap tyres on my XC bike more often. Being tubeless it’s a pain in the ass to have to muck out the sealant, dispose of it and then do another so I have a cunning plan…… 😉
I want to buy an extra-light race inner tube with removable valve core and fill it with sealant, have done this before anyway before I went to tubeless proper. This means I can easily swap tyres easier with a lot less faff.
Other than a bit of extra weight, this seems a good idea to me. I figure it should seal pinch flats (if I get them) and anything else like a tubeless would but allow me to change tyres when I want.
Any down sides to this?
Ps. I’m not buying slimes, they weight almost 700g which is basically another tyre!
Posted : 26/06/2022 1:05 pm
Would the talc inside the tube not cause the sealant to clog up?
Posted : 26/06/2022 1:34 pm
If you are only relying on tubeless sealant to handle small punctures then your idea should work. However you'll not benefit from lower tyre pressures/increased grip as the slime idea won't handle snakebite punctures very well.
Posted : 26/06/2022 2:15 pm
Unhook one side of the tyre, so you can syringe out the sealant that pools at the bottom, keep that in a jug and use it to fill up the next tyre, topped up with some fresh.
Seems to work well here. Might be a bit dirty, but have had no probs....
Posted : 26/06/2022 2:36 pm
@kayla1 never though of that but seemed fine when I did it years ago. Just never asked anyone about the cons in the past.
@scotroutes, ok. That’s an interesting one to think about. I suppose if I carry some repair kit with me at least if it does happen and the sealant can’t save it I can patch it to get home.
Just reuse the old sealant as susepic says. I’m always changing tyres and do this every time.
Posted : 26/06/2022 2:53 pm
I just swap the sealant into the new tyre and top up if needed. Been testing wheels and tyres A LOT in the last three weeks so have got it down to a fine art. It's always good when the seat with just the track pump too
Posted : 26/06/2022 3:07 pm
Thanks all.
I’m gonna start with reusing sealant. Makes the most sense to be honest.
Posted : 26/06/2022 3:56 pm
 igm
Or get a couple of spare sets of wheels 😉
Posted : 26/06/2022 4:05 pm
