Skipping Chains
[Closed] Skipping Chains
9 Users
Hi,
put a new chain, cassette and chain ring on, riding 1 x9.
the chain skips and it drove me mad yesterday!
the mech andjockey wheels are old, though got good teeth on them. the set up ran perfectly prior to this. i also re set the cable.
any thoughts?
s
Posted : 30/05/2011 8:41 am
It's usually old cassettes that do that.
Maybe you've got the wrong sized chain on?
Posted : 30/05/2011 8:54 am
Stiff chain link?
But personally I skip with a rope 😉
Posted : 30/05/2011 9:25 am
a rope may do a better job....
done the links, i thought about the chain, so checked out a new 9 speed against this one and it looks like its exactly the same, width, length and model number on the chains.
i am going to the shed to check it out again and will report back
Posted : 30/05/2011 9:37 am
no stiff links - where it were joined perhaps ?
Posted : 30/05/2011 9:47 am
Chain too long perhaps?
Posted : 30/05/2011 9:51 am
I had exactley the same problem, and changed chain, chain ring, cassette etc and still had the problem, until I changed the shifter - it has run great ever since!I since found that the adjuster on the shifter had worn and I could never keep the cable tight enough, it might be worth a look at.
Posted : 30/05/2011 10:35 am
chain is run short, as its a 1 x 9
i think it may be the top jockey wheel, shed visit did not happen as i was putting a new window in said shed!
wednesday is my next day i can look at it. never had this problem before though
arghhh!
Posted : 30/05/2011 8:23 pm
Is the large cog on the cassette the same size as the old one?
Posted : 30/05/2011 8:26 pm
if it's not chain rings, cassette or chain, then it could be a slightly bent gear hanger. That's caused me a skipping chain in the past. Have a good look at the alignment.
Posted : 30/05/2011 8:31 pm
the chainring, casette and chain are all new, i may play around with the screw( not the limiters) .
may have to be a new mech!
s
Posted : 30/05/2011 8:57 pm
I had my rear mech work loose and cause the same problem.
Posted : 30/05/2011 9:56 pm
may well be the b screw.
wase the cassette the same ratios?
Posted : 30/05/2011 10:03 pm
erm, some subtle adjustment worked a treat, doh!
did the limiters etc as well.
cheers for your replies
Posted : 04/06/2011 9:33 am
