Sizing up Giant Tra...
[Closed] Sizing up Giant Trance 27.5 2015
9 Users
Seen a size medium I,m interested in but I,m only 5,6 and a bit!Long or short reach?I guess the equivalent of size 18 might be stretching things/me a bit.Thanks for any advice.
Posted : 29/06/2016 5:02 pm
I'm 5'8 and have a medium Trance, I'd say you could get away with it, theres possibility of running a shorter stem if you felt stretched.
Posted : 29/06/2016 5:12 pm
I'm 5 6 and ride a small Anthem. I'm short legs, long torso, and at times wish I'd gone medium
Posted : 29/06/2016 5:33 pm
Top bargain innit! Good job my shopping mate's 6ft 5.
Posted : 29/06/2016 5:41 pm
5-8 and ride a medium with a 50 mm stem. As long as you have enough room for a dropper I think you'll be fine.
Posted : 29/06/2016 5:42 pm
Thanks all.Anybody know what Scuttlers on about?
Posted : 29/06/2016 6:17 pm
I'm 5.6 and a bit and ride a small. I demod a medium for 2 weeks before I got the small. Totally rideable but I prefered the small.
I do have fairly short legs.
Posted : 29/06/2016 7:14 pm
Fair point kiksy,do you think I'll need a shorter stem?There's also the issue of the dropped post to consider.
Posted : 29/06/2016 7:48 pm
The oem stem is 70 mm, to keep up with the Jones's I now have a 50'm.
It was back in 2014 I had the demo medium so it's hard to remember exactly what it was like, I just remember as soon as I got the small I knew I'd made the right choice. I do think it's down to personal opinion and fit rather than a hard and fast rule. I was quite happy riding around on the medium and as you say you can get a shorter stem.
Oh the small came with 170mm cranks and I think the medium is 175mm.
As for dropper I had an issue getting a 125 mm reverb low enough on the small, which I solved by removing the Connectamagik thing:
http://singletrackmag.com/forum/topic/reverb-stealth-the-black-connector-bit-what-does-it-do
From memory I think I worked it out Thomson posts would never work for me as they are too long, but most others would. On a medium I reckon you'll be fine.
Posted : 29/06/2016 8:19 pm
Was the reach ok but the leg length an issue I have 29 inch inside leg.
Posted : 29/06/2016 8:47 pm
FWIW I fond the large Trance which was correct size for me according to the Giant sizing chart to small to be honest(As did everyone on here when I put a picture up)
Also it was very low at the front compared to anything else I have ridden.
Posted : 29/06/2016 9:02 pm
My Inside leg is 76cm , arms 60cm if that helps.
Posted : 30/06/2016 5:35 am
i'm 5,6 and ride a small and it is perfect!
Posted : 30/06/2016 6:57 am
I have a large trance and am 6ft, I also have a large Reign which is equivalent to an XL trance. When seated, the distance between my saddle and bars (in drop and length) is the same. The difference comes when you stand up, the Trance is 20mm shorter in the reach which is noticable. What I'm saying is you can do a lot with saddles and stems to shorten/lengthen bikes.
The large trance will be more stable at speed compared to the medium, the only concern would be the seat tube height and being able to get the dropper post low enough. The 2015 giant dropper has a 25mm layback (I think) which will make it difficult to get the seat close enough to the bars, a reveb is inline so gets round this potential issue. You will almost certainly want a stem shorter than 50mm, probably close to 35mm.
Its useful to have the option of running the bars low without having to run negative rise stems and bars!. 120~mm head tube on a large is a pretty sensible number. I sold my Sherpa as I couldn't get the bars low enough!
Posted : 30/06/2016 7:41 am
