Size small Canyon E...
[Closed] Size small Canyon Endurace owners...What height are you?
1 Users
OK, my thanks to contributors to a previous thread about the merits of a non disc endurance bike which gave me the confidence to go for the Endurace
As I'm buying online the big problem is trying to predict the best size without a test ride
Using the Canyon sizing tool, (which bases frame size on inside leg length), I'm a small using my 80 - 81cm inside leg length
And actually even if I drop to 79cm its still a small Only a 78cm inside leg triggers the sizing tool to recommend an extra small
Now after a lot of reading around I discovered the VCLS seat post has a maximum insertion limit that leaves around 200mm of seat post exposed
This coupled with the 510mm set tube means a minimum top of saddle to bottom bracket length of around 700mm Looking at my MTB and Brompton I think i'll be looking at 680 -690mm
So can anyone reassure me they have an Endurace in small and have an inside length or height similar to mine or less ?
many thanks
MC
Posted : 30/03/2016 8:51 pm
