Hi I've got the above frame and was trying to work out the pull rod as I'd rather have the bike trail ready than Fr/Dh can anyone help? Cheers
Depends wich version of pull rod, frank made a couple, but basically loosen the top and bottom collars and then turn the centre rod, the bike with slacken its seat and head angle or steepen depend wich way you turn it. When you are happy, just tighten up the locking collars
Thanks tazzymtb the top collar moves but the other 2 I cant move so I will give it another go tomorrow thanks again much appreciated
Have a look on the old sinister website/forum from memory the bottom collar is threaded the opposite way so makw sure you are loosening it not tightening it to buggery!!
So I have been tightening the bottom collar then !! should of looked at the threads - thanks again
