I have recently fitted one of the current (eg cream) Swift rigid forks to my older (blue) Swift frame. It looks like the fork has a fair bit of clearance so I was wondering if it'd take a (26?) fat front wheel.
Has anyone done this and if so how fat can you go? I've heard that it'll do 29+ too - any feedback on that?
TIA
Not sure about full fat but a knard on a 50mm wide rim fits easily
Ooooo. Did you get the fork new from Sam? Is the A-C the same as the old blue one?
Tried a Knard on a Crest in the blue fork and it's a no-no.
Thanks.
Got the new fork brand new from the classifieds.
The blue forks came in 485 originally then 470. The cream one is 470 but visibly wider /more clearance hence it's raised my question.
What would full fat be considered to be? 4"?
bump for the daytime
3.8" won't fit but I've got a chronicle on a dually in the wider version with plenty of space
nemesis - Member
I tried that with one of the original Swifts. It just rubs even with a very narrow rim (40mm). The tyre was 88mm wide on that rim.
So, unless something has changed, it won't fit.
[url= https://farm5.staticflickr.com/4095/4894227951_aa07b8fb85_z.jp g" target="_blank">https://farm5.staticflickr.com/4095/4894227951_aa07b8fb85_z.jp g"/> [/img][/url]
It also won't fit in an On-One carbon fork (tubed one).
[url= https://farm5.staticflickr.com/4114/4894821382_40dc6b4414_z.jp g" target="_blank">https://farm5.staticflickr.com/4114/4894821382_40dc6b4414_z.jp g"/> [/img][/url]
For my early experiments a few years ago I ended up bodging together a rigid fork out of a suspension one.
[url= https://farm5.staticflickr.com/4114/4904618215_13d0c24ea7_z.jp g" target="_blank">https://farm5.staticflickr.com/4114/4904618215_13d0c24ea7_z.jp g"/> [/img][/url]
I measured the fork and it's around 3.9" clearance around where the tyre would (I think) go so 3.8 being the absolute limit sounds right.
So, by my reckoning 3 or maybe up to 3.3ish would fit ok though I'm now wondering if that's really wide enough to be worthwhile over a relatively wide 29er tyre.
epicyclo - the cream fork is clearly wider than the blue forks.
The 29x3 chronicle looks very wide compared to the 2.4 ardent on the back. The rim is 45mm tho
So it sounds like you're going with 29+ rather than a 26" fat which I understood would be closer to a 29er wheel with a normal tyre.
