Singlespeed tension...
[Closed] Singlespeed tensioner for vertical dropout
4 Users
My ancient tensioner has given up the ghost (it's so old that I can't remember what brand it was, but it was crap) so I wonder what are the current best buy is. It must be cheap, likely to be available in an LBS (none of this online malarky) and have a very strong, adjustable spring tension.
Your thoughts please.
Posted : 20/01/2014 6:42 pm
Either buy online from on one etc or go look in your lbs as they will know what they stock.
Posted : 20/01/2014 6:59 pm
I've got 2 on-one tensioners (I know you said not online, but they're fairly generic and I'm sure a LBS could source something similar). One on a singlespeed, one on an alfine 8. Bith work with no issues, no chain slippage etc. with good tension
Posted : 20/01/2014 7:46 pm
This http://www.charliethebikemonger.com/4jeri-tensioner-29-p.asp, not the quietest, the metal guide rubs if you run a 1/8th chain, I took the guard off as it's pointless anyway.
Posted : 20/01/2014 8:58 pm
