Singlespeed ratios ...
[Closed] Singlespeed ratios - easier gear than 48/18?
8 Users
I moved house recently which means my commute is a little bit hillier, and my 48/18 is a bit of a tall gear when I'm tired.
My freewheel isn't in the best condition so was thinking about replacing it with a better quality one and going for 19 teeth instead.
Alternatively, is dropping to a smaller chainring a better idea? Maybe to 46?
How much difference will going to a 19t freewheel make? I'm not after a massive change, just a little easier. I currently spin out c 23mph and don't want to go too much lower and lose this top end speed
Posted : 16/04/2014 9:22 am
48/18 = 2.67
48/19 = 2.52
2.52 / 2.67 = 94.6% = eg it'll be 5% easier
You'll also spin out 5% earlier eg at 23 x 94.6% = 21.7 mph
Posted : 16/04/2014 9:29 am
 nbt
this will help
http://sheldonbrown.com/gears/
Posted : 16/04/2014 9:33 am
on most road cassettes there would be a 2-3T jump from an 18T, so about 1/3 or a gear - **** all really.
Posted : 16/04/2014 9:43 am
A 19T freewheel will make little difference. 46:18 would be my choice to gear down. I bought a used langster which had 42:18 freewheel and it was far too low (it's 42:16 now - the standard choice for rolling terrain).
If you ride it fixed, it sometimes feels like a cog lower because the drivetrain is more efficiently coupled to your legs.
Posted : 16/04/2014 9:53 am
I don't know what freewheel you are running but I do know Shimano ones only come in 16, 17 and 18T so I would have to swap the chainring instead.
Posted : 16/04/2014 10:22 am
 D0NK
it's 42:16 now - the standard choice for rolling refrained
I'm running this on my CX, find it a bit spinny on road TBH.
How long have you been doing the route? Can I suggest mtfu - see if you acclimatise?
Posted : 16/04/2014 12:34 pm
Fixed or free? You can spin much better when fixed, so it doesn't feel that low. It's geared for 80rpm at 16.5 mph. So a reasonable cadence/speed range of 80-120 or 16-24, with "excursions" to 30 downhill.
Posted : 16/04/2014 12:56 pm
42x16 on Langster for my flatland commute spins up to 25mph and can go beyond but it gets a bit much. Spin spin spin
Posted : 16/04/2014 1:19 pm
 D0NK
TiRed ignore me, I read 42x18 but quoted 42x16 which is a gnats chuff away from 48x18 anyway. 42x18 is on my CX and as you said too low on road.
Posted : 16/04/2014 1:48 pm
