Singlespeed - chain...
[Closed] Singlespeed - chain slipping/skipping Q
7 Users
I'm a relative newbie to SS'ing - I converted my old bike to SS using one of CTBM's kits - all good - so much so, that the chain, and sprocket wore out so I have replaced them with new and gone to a SS-specific Salsa chain ring.
On the highly scientific 'test it up and down the street' the chain seems to skip/slip when under load (honking out of the saddle)
I think the chain-line looks ok. The sprocket was just a cheapo 16t from CTBM.
Would a more expensive cog with taller teeth make much difference?
Would shortening the chain help?
Thanks in advance
Posted : 20/02/2013 10:20 pm
Frame flex or slightly bent hanger can result in skipping.
Cn you get the tensioner to push up for better wrap?
Posted : 20/02/2013 10:34 pm
get that chain as short as possible
Posted : 20/02/2013 10:39 pm
Flex,
Freehub skipping?
Chainwrap round the sprocket - try a push up tensioner (bodge with cable tie to test or shorter chain)
Narrow chain meaning that the sprocket teeth are not engaging the chain properly (can also be a bent hanger throwing the alignment out on the front chainring) - try a straight edge to check the chain line with tensioner fitted.
Posted : 20/02/2013 10:40 pm
Don't know about the tensioner, would have to look to see if I could reverse the spring somehow, so it pushed up
Posted : 20/02/2013 10:41 pm
I had the same tensioner and the same problem, having the chain as short as possible and therefore increasing chain wrap sorted it for me. I wasn't able to reverse the spring, you may have more creativity/engineering skill than me however. I run a Gusset bachelor and it's does a fine job.
Posted : 20/02/2013 10:52 pm
 Keef
if you cant reverse the spring,take it out,and use a cable tie wrapped around the chain stay and tensioner in 'pull up mode'
it WILL work !
shorten chain as much as possible,a half link may help.
Posted : 20/02/2013 11:29 pm
 Muke
Shorten the chain and ask Charlie what he thinks
Posted : 21/02/2013 8:09 am
Check the tensioner is loaded and working hard.
If you can get another link out of the chain it will help a lot.
Let me know how it goes
Posted : 21/02/2013 8:36 am
