What Geer Raito do you people use on a mtb which i only for road use so its got slicks' on it.
46:13, probably unless I use 32:45. Or else it's 36:19
Where are you riding? How hilly or flat is it? How fit are you? Are you a spinner or a grinder? Too many variables for a sensible answer.
Is quite hilly round here as i l live in Chorley Lancashire. I would say i was spinner not a grinder if that helps. Drofluf
I'm just down the road in bolton. Running a similar bike to you for commuting for 6mothz or so. Used all sorts 34 11/13/15 Allways a compromise to be made but I'd say the 13 was best. Poasible to mash up most stuff, not too spiny on the way down.
I've just gone 1x10 so I have the set of gusset double 6's above I was about to bang on the bay if you fancy them?
Sorry was a bit frivolous last night.
On the road I run 42:16 , but that's on a road bike. On an mtb I guess you'd be limited to a 34T up front so I'd start at 34:13 or thereabouts and see how you get on.
Work in inches and the wheels size doesn't matter. I'd go for the high 60s.
When I used to run this setup I used 48-16 but it was relatively flat. You can fit big sprockets just use the outer position on the cranks.
^This. It's what I run on my commuter (about 69 gear inches) for a commute which is all, a reasonably gentle, uphill one-way. It's tougher than I'd choose if I had gears, but it more than does the job and it's not too spinny anywhere else.
I ran my old MTB on the road with 42:15 up in Cumbria, was good on the flat ok on slight inclines but a proper gurn-fest up steep hills.
~52" xc
~63" flat-ish xc or a mixture of xc and road
~70" road
IME these are a good place to start, raise or lower to suit you and your chosen route.
[url= http://sheldonbrown.com/gears/ ]sheldon's gear inches (and more) calculator[/url]
an MTB with 2.1 tyres 44:16 (an easy combo to get hold of) will give you 71" but if you've got knobbly tyres and suspension you may want to go a bit lower. Narrower slick tyres and rigid will save you a lot of effort.
+1 Donk...
I use 52" on my Winter SS MTB (32-16, 26" wheel) and ~74" on my commuter fixie (44-16, 27" wheel)...
If I was putting slicks on the SS MTB for road use I'd probably be looking to increase the ratio by fitting a ~13T sprocket at the back giving me ~64" I could get that up most hills (certainly those local to me) and It would be OK on flat roads, its an MTB not a road bike so I guess the gearing should be a shade easier to accommodate that
