Just wondered if anyone makes one and if they are available.
Kona "A" if you can get one.
Kona Cowan.
Lenze Milkmoney.
Damn that Lenz is ugly
Nicolai helius can be built with Rohloff.
Just sold mine:-
http://singletrackmag.com/forum/topic/fs-kona-a-rohloff
You already know that you can use any old frame you like with a tensioner, right?
To get one without a tensioner, you'll need one where the BB is within the main pivot. This has some disadvantages when it comes to suspension design, though, as you're limited to single pivot designs with the pivot in a compromised position - it's likely to bob quite badly. Commencal did a nice-looking one, not sure if they still do.
Airnimal Rhino, if you like small wheels.
For heavy but 'rad', see also: DMR bolt, Cove G-spot
A few folk on here have 'normal' full suspension frames as singlespeeds with sprung chain tensioners or bodged rear derailleurs too.
3 things you need -
1) Some way of transferring torque to the frame. The Rohloff 'OEM' dropout is the most elegant and is built to handle the stress. A 'speedbone' which attaches to the brake bosses is the other. Rarely causes issues but can.
2) A way to tension the chain. Either
- sliding dropouts and a pivot around the BB so no change in chain length. Restricts you to a very small number of frames and compromises suspension design
- A chain tensioner (and some sort of chainguide at the front). Rohloff's parts work well and last a long time. Very rarely dump the chain with them - the only issue is clearance between the guide and cranks with some crank/chainring combinations.
3) some way to route the cables. For light shifting you want as smooth a route as possible - under the bb and under the chainstay normally works best. Cable ties/stick on guides will work but for elegance best built with the frame.
Nicolai, of course, offer OEM dropouts and Rohloff cable routing as no cost options on all of our frames.
My Kona A is lovely.
Looking very similar to Nicknoxx's but singlespeed and with a belt:
[url= http://farm7.staticflickr.com/6018/6208889226_45b5230fd2.jp g" target="_blank">http://farm7.staticflickr.com/6018/6208889226_45b5230fd2.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/6208889226/ ]DSC_0093[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
I used to run a Rohloff on a Foes FXR
Used Speedbone with a Rohloff chain tensioner which worked very well. Did not have a chain device and rarely had any problems.
Foes did not have Rohloff cable routing but as long as cable bends are not too tight shifting should be fine.
Awful pic, chain is not even on FFS 🙄
Ive just machined* myself a monkeybone for my Scandal. Id previously hacked my speedbone for use on the On-One slotted drop outs (where the brake mounts are inside the rear triangle, meaning the speedbone wont fit as required).
[img]
[/img]
[img]
[/img]
[img]
[/img]
But a new one for the scandal (with mounts in the normal position on the outside of the rear triangle) would cost £35+. A monkey bone is $35+ from the US. So an £8 adaptor, grinder, files, pillar drill and a lot of cursing and Al swarf later:
[img] https://lh3.googleusercontent.com/-FXqCL03Z_IQ/TtYDcfHfdAI/AAAAAAAAA7s/fg57oMzOagE/s400/IMAG0473.jpg [/img][img] https://lh6.googleusercontent.com/-4W08qW7ygVQ/TtYDo5ug3oI/AAAAAAAAA70/livKhGq24Bc/s400/IMAG0474.jp g" target="_blank">
https://lh3.googleusercontent.com/-FXqCL03Z_IQ/TtYDcfHfdAI/AAAAAAAAA7s/fg57oMzOagE/s400/IMAG0473.jpg [/img][img] https://lh6.googleusercontent.com/-4W08qW7ygVQ/TtYDo5ug3oI/AAAAAAAAA70/livKhGq24Bc/s400/IMAG0474.jp g"/> [/img]
[url= http://www.endorfinbikes.co.uk/bikes/vp4rsl/vp4rsl.php ]endorfin[/url]
Solid Flare?
IMHO one of the best looking*.
5'' travel
URT
Steel
29er
More [url= http://www.castellanodesigns.com/Zorro.html ]here[/url]
*Runs off to hide from the sticks and rocks being thrown
why dont URT designers just put some effort into a damped suspended seatpost that could be used in any HT frame instead?
Stoner - Memberwhy dont URT designers just put some effort into a damped suspended seatpost that could be used in any HT frame instead?
Not a fan Mr S?
I agree that these are a bit marmite .... but I look marmite 😉
Seems a straightforward way to make SS full sus frames look tidy
Not quite what I mean 😉
thinking more like a thudbuster, but in a cylinder design a bit like an uppydowny post.
Stoner - MemberNot quite what I mean
Give over a Thudbuster will never take off like the Softride .........
Oh wait ...... 😆
I'll have an old G-Spot frame for sale quite cheap soon...
