Single speed cog on...
[Closed] Single speed cog on Hope Freehub?
8 Users
Having seen the damage a lower-end cassette can do to a Hope freehub, does a thin SS cog not do even worse? Are some better than others at avoiding damage?
Posted : 14/10/2013 11:08 pm
Replace the aluminium Freehub with a steel one.
I use a wide base Velosolo cog on the steel Freehub and there using a mark on it, not sure the aluminium one would be the same.
Posted : 14/10/2013 11:17 pm
Used a ss cog on mine for over a year now. No damage.
Posted : 14/10/2013 11:20 pm
I had a Surly cog on a Hope hub with a steel freehub and had no issues over 2 years of use.
I had to replace the cog, chain and chainring in that time; but the steel freehub was fine.
Posted : 14/10/2013 11:29 pm
Wide base 16t cog on a Hope aluminium freehub is fine for me.
Posted : 15/10/2013 1:01 am
 Moe
I've got a wide a wide 16t on mine, and it's fine although I did trash the free hub bearing this week, it was pretty well used! I guess the sort of terrain we ride would make a difference? I mean, in Thetford I don't spend much time stomping it up hills!
Posted : 15/10/2013 1:36 am
Got slight cutting with a thin 22 on my pro 3 sp hub in 24 hours use at puffer
Changed to a wide base 16 after that and no further issues in 3 years
Posted : 15/10/2013 6:31 am
I use the on-one groove armada cogs on Hope hubs, not had any issues.
Posted : 15/10/2013 6:51 am
